Onn onc50ub18c05 50" led
  • yotaman
    • May 2015
    • 12
    I have searched and not an electronics person so forgive me if I am about to sin and fixing to ask dumb questions.
    In-Laws set they state it started to start up slower and slower till just black screen but they think still had sound.
    I plugged it up and the Red status light is on till you push start and then it goes out and with the back off the only illumination I see is a red glow from the optical port. I checked the voltages on the connector that leads to the control buttons and have 5V where it states it should.
    There is only two boards Ima call one the main big board and the other is the small or maybe Tcon board. I have no issue replacing one and see if that is it then the other my only concern is the LEDs' or something in the screen may be the issue ??
    Any tips, prayers or advice is appreciated.
    Thanks,
    Yotaman
    • 12328
    • U.S.
    Re: Onn onc50ub18c05 50" led
    my crystal ball is a little foggy, can you post a good clear straight on picture of the whole back as to see what it is and how everything is connected.
      • 12328
      • U.S.
      Have a good read of Budm's most excellent sticky above, here's a link: https://www.badcaps.net/forum/showthread.php?t=25810
      • yotaman
        • May 2015
        • 12
        Thank you for the response. When I get a chance i will get a pic of the back.
        Thanks again,
        Yotaman
        • yotaman
          • May 2015
          • 12
          See attachments
            • 12328
            • U.S.
            heat up the big board with a hairdryer for a couple minutes, what I do is start with the electrolytic caps, heat those up for a couple minutes then try it, see if it stays on longer or if theres any change, dont wait til it cools down try it while its still hot, if no joy try heating the rest of the little blue ceramic caps and the others, if that doesnt do anything try heating the rest of the board, with that symptom I suspect bad capacitor/s. From what I gather they make these onn tvs just as cheaply as possible but theyre prolly still better than samsung.
            • lotas
              • Jan 2016
              • 4848
              • Russia
              Check the voltage on this connector (out backlight) when you turn it on, it rises and if the backlight is not working, the voltage will drop sharply.
              • yotaman
                • May 2015
                • 12
                Thank you both for your responses.
                Blow dryer trick did not seem to phase it.
                Voltage (DC right) on the red wire pin of that terminal did exactly what you described. Does that say backlight is bad ? if so how hard to change it ? I have only swapped a few TV boards.
                Thanks again Guys
                • yotaman
                  • May 2015
                  • 12
                  bump
                  • yotaman
                    • May 2015
                    • 12
                    bump bump please
                      • 12328
                      • U.S.
                      there: https://www.youtube.com/watch?v=bYJKOFfNGkg
                      • usyusy
                        Battery charges till some specific percentage % ?
                        by usyusy
                        hi to all dears,
                        if any battery is charged upto some specific percentage like Dell Latitude 3330 charges upto only 34%.
                        what could be its possible reason...,regards
                        03-28-2022, 12:52 AM
                      • acedogblast
                        by acedogblast
                        11-02-2024, 05:13 PM
                      • dicky96
                        Gigabyte X470 Aorus Ultra Gaming - does not power on
                        by dicky96
                        So this is the third of three AM4 motherboards I have here
                        This one is compatible with my A6-950 test CPU. The CPU socket looks good on this one and I can't see any physical damage
                        The SIO is an IT8686E, and I couldn't find the datasheet. There is 5V on the PS-ON switch but the ATX PSU does not get a start signal. Interestingly on he green wire from the PSU I get around 2.4V which very slowly increases - for example in the last 20-30 mins it has reached 3.05V. It does not increase continually like a charging capacitor but goes up and down as little bit - like it is taking...
                        01-28-2021, 06:46 AM
                      • Qattos
                        Laptop shutting down and refusing to restart till some time passes
                        by Qattos
                        Laptop : Lenovo Y520 i5-7300HQ 16GB RAM GTX1050Ti 240GB NVME SSD 1TB HDD.
                        I bought my laptop in 2018, the guarantee ended in May of this year, it's been working(mainly gaming) fine for all this time except a minor issue with Windows warning me about power surge on USb port all the time when gaming, and it wasn't my mouse, I tried another mouse and the same issue, so I thought it's a driver problem and just ignored it.
                        My real issue:
                        My laptop appeared to be shutting down randomly at first, and when I try to restart it, the keyboard lights turn on, the...
                        06-22-2020, 08:39 AM
                      • Sojke
                        Acer Aspire E5-575G 15 seconds till image appears
                        by Sojke
                        Can anybody help me with this BIOS I have? It takes 15 seconds to display image from the point of pressing the power button and the LEDs lighting up.
                        After 15 seconds, aprox. , the image is displayed and laptop boots and operates normally.
                        BIOS inside the machine (From a machine with GeForce 940M GPU):
                        BIOS from before I replaced it (Does not work, no image):
                        Laptop full model is:
                        E5-575G-56BE
                        NXGDZED0837111926F7600
                        i5-7200U , GTX 950M 2GB , DDR4 type System RAM
                        Please...
                        04-14-2020, 11:33 PM
