Ahb8016t-3521dv100 v2.02b
  • ugura09
    • Jun 2016
    • 93
    • aydın
    Eeprom: FM24C08D
    MB: AHB8016T-3521DV100_V2.02B
    CPU: Hi3521_DRBCV100_CPBQL2031_2032-CN_03
    İşlemci Yanık Cihazdan Kopyadır Şifre Var Yada Yok Bilinmiyor
    Aldanırsın Yıllara
  • kayali
    • Jul 2023
    • Turkey
    Re: Ahb8016t-3521dv100 v2.02b
    thanks
    • arif3203
      • Feb 2021
      • 55
      • Banyumas
      Please share this firmwire Ahb8016t-3521dv100 v2.02b
      • SidneyCanadas
        93C46 and 93C56 EEPROM
        by SidneyCanadas
        I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
        https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
        Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
        06-14-2023, 01:16 PM
      • dmccul2698
        Pioneer DEX-P99rs "No EEProm " diagnostic code.
        by dmccul2698
        Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
        1). Understand the schematic and check the connections between the EEProm and DSP
        2). Check the functionality of the EEProm
        I don't know if this is the unit's problem but it's a place to start.
        I have little to no electronic experience...
        04-08-2024, 05:32 PM
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • 247it
        ThinkPad E15 G4 PD Controller TPS65994AE EEPROM
        by 247it
        Hi, I have a ThinkPad E15 G4 I am working on for fun, the PD chip is not talking to the charger, it's stuck at 5v, I have replaced the PD chip three times now (new chips) and always the same result, I have checked for shorts, correct voltages on the PD IC etc - 5v 3v, and the 1.6v on the cc lines, even replaced the USB C port protector IC and the charging port,
        The PD IC has a EEPROM connected directly, it's the one in the image attached, I assume the PD chip will not start without some initial commands stored in the EEPROM, the PD IC never shows in device manager, i backed up the
        03-23-2025, 03:53 AM
      • facta
        LENOVO THINKBOOK G4 USB C EEPROM
        by facta
        I have lenovo thinkbook 15 g4 PN: LA-L931P REV:1A with TPS65994AE (bga) can't negotiate 20v contract but can turn on with a charged battery; can anyone help with a working firmware for the eeprom (U15) or guide on how to create one through TI customization tool. i have attached my original eeprom in case it could help....
        03-06-2025, 09:39 AM
