Nikon D5500 – what is this component pls ?
  • corrize
    • Apr 2021
    • 272
    • France
    Hello, liquid damage for this Nikon. Do you know what is this component pls ? I can't find it on the web.
  • corrize
    • Apr 2021
    • 272
    • France
    Re: Nikon D5500 – what is this component pls ?
    pdate : I noticed, it’s not « 513 » but « 5J3 ». That should be a voltage regulato UM1750S-13. But I can’t fin it with the same square box…
    • R_J
      • Jun 2012
      • 9535
      Clean the residue off the board and the ic, it may still be ok, plus you can read the number better.
      • mon2
        A1466 Macbook Air (Liquid damage repair)
        by mon2
        Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
        Macbook AIR Model A1466 Diagnostic 09-01-2021
        Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
        Problems & Resolutions
        1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
        09-01-2021, 09:31 AM
      • rilley
        MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
        by rilley
        I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
        I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
        My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
        And the resistor L4004 is literally burned.
        From what I see from the schematics, it does not affect any other rails, only the connection to the display...
        07-10-2024, 01:57 AM
      • Jenzo
        MacBook A1989 overheating after liquid damage
        by Jenzo
        Hey everyone,
        Had a MacBook pro 13" 2018 (A1989) come in for liquid damage. The only liquid damage was all around UB400. It was most likely soda, so there wasn't that much corrosion. I reflowed the UB400 and the QB chips with some flux, and replaced the caps/resistors that were in bad shape. Seemed to be working fine at first, but the next day when testing it again, the laptop charges and boots fine, the CPU would overheat, and U7210 would get to 70 degrees Celsius as well. I'm testing with only screen and battery connected at this point.
        I can't figure out how...
        05-13-2023, 07:58 AM
      • mitchw
        MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
        by mitchw
        Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
        It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
        I quickly took it apart and washed the liquid residue off the mainboard.
        The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
        The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
        Now the laptop...
        07-16-2025, 07:55 AM
      • larrysito111
        dell alienware m17 r5 LA-L761P liquid damage no image on lcd 2red 7blue runs on external
        by larrysito111
        got here a liquid damaged alienware
        the laptop had damage in the area of the kb9542qf2 all sorted and now laptop working and turns on but i have no display
        so if i start and connect usb-c display it works otherwise it is giving me the 2red and 7blue
        so with the usb-c external monitor is getting to bios and OS
        otherwise not
        so if it is in the os and i connect another lcd via onboard hdmi it is working no problem 2 lcds (1 usb-c + 1 hdmi)
        but still not the internal monitor
        (tested 3V and 5V going to the...
        06-12-2025, 04:16 PM
