Help needed to revive dead Asus EXA082XA AC adapter
  • mikey5791
    • 521
    • Malaysia
    This model EXA082XA Asus ac adapter just died.
    Opening the case, there is no burn mark or any damage component. Glass fuse still has continuity. Diodes and 2 transistor has not shorted. I just suspect a 8 pin ic label Chip Rail CR-LSN69 but unable to get any datasheet.
    Does anyone know how to test this ic or any equivalent substitute such as TOP258PN can be used?
    Any kind assistance and guidance is highly appreciated. Thank you.
    • 31288
    Re: Help needed to revive dead Asus AC adapter
    check the output cable for breaks or shorts.
    people like to abuse psu's by wrapping the wire around them all the time.
    • mikey5791
      • 521
      • Malaysia
      Hi stj,
      Checked the output cable. It has continuity from multimeter probing. No breaks or shorts.
      I did a dc voltage checking with live ac power on.
      The big brown main cap and the nearest 3 pin transistor has about 250v dc. But there is no voltage on capacitor C5(22uf50v). This should be the startup cap. So i suspect the 8 pin ic on the primary side is bad. Fyi, i don't detect any other voltage beyond the C5 cap.
      • lotas
        • Jan 2016
        • 4859
        • Russia
        You should have a big capacitor around DC 300v, check that capacitor.
        • mikey5791
          • 521
          • Malaysia
          Hi lotas,
          Sorry my mistake was that earlier on i took dc reading from an analog multimeter. Using a digital multimeter, i got 324vdc from the main big cap.
            • 31288
            yea, rectified mains is x1.41
            check for bad resistors that feed the mains dc to the startup cap
              • 31288
              Re: Help needed to revive dead Asus EXA082XA AC adapter
              based on this:
              http://www.chiprail.com/pd.jsp?id=86#_pp=2_321
              • mikey5791
                • 521
                • Malaysia
                Hi stj,
                Sorry for late reply as i had been occupied with some other matter.
                Found one resistor R76(brown,black,green,gold) which should be 1M ohm but no reading on DMM after i desolder one leg.
                I will look for replacement and see if it fix the no power issue.
                • mikey5791
                  • 521
                  • Malaysia
                  Hi stj,
                  Finally i got time to buy the 1M ohm resistor and replaced the bad one at R76.
                  Now the AC adapter output led lights up and it is working. Great thanks to stj for the help.
                  • mikey5791
                    Help needed to revive dead HP AC adapter
                    by mikey5791
                    Got this HP AC adapter model HSTNN-CA15(output 19.5V, 3.33A) for HP laptop which suddenly died yesterday.
                    Opened the adapter casing and did not find any burning part, loose or broken wire but the square T3.15A fuse still has continuity.
                    I pulled out the biggest green resistor nearest to main cap at CX2. The resistor has 5 band which is red,red,gray,gold,white. Is this a 22.8 ohm 0.5w type resistor(lenght abt 1 cm)? Please correct me if i m wrong. It measured about 0.4 ohm on dmm, so it is bad. I have no exact replacement so i use a 30 ohm 2w from my stock but...
                    09-18-2022, 07:45 PM
                    HP ProBook 650 G3 + USB-C Universal Dock w/4.5mm Adapter Notebook 600 Specification for Upgrade or Repair
                    This specification for the HP ProBook 650 G3 + USB-C Universal Dock w/4.5mm Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 650 G3 + USB-C Universal Dock w/4.5mm Adapter boardview and 650 G3 + USB-C Universal Dock w/4.5mm Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                    09-06-2024, 06:48 AM
