Adding Passive PFC coil to PSU?
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    So I want to swap another PSU into this unique case that has had the original guts fail. The PSU case was designed for a PPFC coil, so I'd like to incorporate it into the drop in.
    So I really can't remember. Can't you just drop in the PPFC coil? Most PCBs are labeled for them but I really can't remember. There isn't any circuitry that needs to be added? The one in question has a polypropylene capacitor attached to it:
    Would I just install this where the circled jumper is?
    How much does the coil improve the PFC %, realistically?
    I will make a separate thread for the case replacement.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Adding Passive PFC coil to PSU?
    Yes it is as easy as you theorized.
    The PF will increase from ca 0.5 to around 0.7 if you add PFC.
    Here are some more details: https://www.silverstonetek.com/techt...h_pfc&area=usa
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Thanks for the link! Definitely worth it since it doesn't cost anything. It's already got the screw holes to hold it in place as well.
      Do I install it at the circled jumper, or do I need to post an overhead shot and/or the bottom solder side?
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        The intent is that the circled jumper is removed and then there should be a connector populated in the square of that silkscreen that your coil connects to.
        Both ways would of course work fine, just verify what I say when you look under the board...
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          Do I need a connector, or is it just preferred? I don't think I have that size, so I may need to just solder it straight to the board.
          Here is the bottom of the board that the PPFC coil is originally in. This PSU was set at 230V only, does that mean the coil would be in a different place than it would be if it was 115V only? I do plan on permanently setting the replacement PSU to 115V. I will post pictures of that one shortly.
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            Here is the PSU that I would like to put the PPFC coil into:
            Side question: I'm fairly certain but since I've been out of electronics for a while, I want to be sure. The yellow line is going to each of the points where the voltage selector switch goes into the PCB. If I want this to be 115V permanently, is this where I would put a wire?
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              The connector is optional of course, a directly soldered wire will always be more reliable if done well, coil will be the same for 115 vs 230v.
              Yes that looks to be right, easy enough to verify with a multimeter in continuity mode.
              Just measure when you close the switch to confirm your idea.
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                Good to know so you think that I should be able to install the coil at that jumper and it should work? I want to be sure before I try. I don't have access to PSUs like I used to so they're more difficult to come by for me these days lol
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  Okay so it turns out the replacement PSU won't work, the PCB is too big I have a Macron MPT-301 and another PSU. The Macron doesn't have any PFC markings at all but the other PSU does.
                  However, there is something that I noticed from looking at other PPFC PSUs online. Some of them have a white and black wire, as well as markings for IN and OUT. Are these for N and L? Does it matter, because this PPFC coil only has two black wires.
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    No I don't think it matters, it is just a coil, not a transformer.
                      ASUS E410MA-BV190TS-CASE Notebook Specification for Upgrade or Repair
                      This specification for the ASUS E410MA-BV190TS-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E410MA-BV190TS-CASE boardview and E410MA-BV190TS-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-06-2024, 10:50 PM
                      ASUS 571GT-AL188R-CASE Notebook Specification for Upgrade or Repair
                      This specification for the ASUS 571GT-AL188R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 571GT-AL188R-CASE boardview and 571GT-AL188R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                      09-06-2024, 11:05 AM
                      ASUS VivoBook X712FA-AU311R-CASE Notebook 17 Specification for Upgrade or Repair
                      This specification for the ASUS VivoBook X712FA-AU311R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU311R-CASE boardview and X712FA-AU311R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      ASUS X712FA-AU306T-CASE Notebook Specification for Upgrade or Repair
                      This specification for the ASUS X712FA-AU306T-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU306T-CASE boardview and X712FA-AU306T-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) Flip Specification for Upgrade or Repair
                      This specification for the ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX461UN-E1042R-CASE boardview and UX461UN-E1042R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-06-2024, 07:07 AM
