Apple G4 AcBel PSU - blink failure mode
  • ChairmanJones
    • Apr 2021
    I have an AcBel PSU that was exhibiting the typical failure mode with the single blink light then no power on.
    I started the rebuild with the shotgun 12, same issue. Fuse has continuity. My question is, has anyone narrowed down the cause to specific caps or is it a case of replace them until it works? What caps should I be replacing next?
  • PeteS in CA
    • Aug 2005
    • 3586
    • USA, Unsure of Planet
    Re: Apple G4 AcBel PSU - blink failure mode
    Some generic questions:
    * Does this P/S have active PFC? If it does, what is the voltage across the big electrolytic capacitor? If it does and that voltage is ~165V, the PFC is not working and that is where to start your troubleshooting.
    * If it does not have active PFC or the voltage across the big electrolytic capacitor is something like 390V, do you have good 5V Standby? If not that is where to start your troubleshooting. If 5V Standby is also OK, then the problem is in the main inverter or output circuits.
    I'm not familiar with the specific power supply, but these are quick ways to localize where to look for problems.
    PeteS in CA
    • a_p3rson
      Apple Watch Charging Controller Schematics / Boardview - 820-02601
      by a_p3rson
      Hi there,
      I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
      You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
      This daughterboard uses an interesting...
      04-21-2025, 11:41 PM
    • DynaxSC
      Stubborn GIGABYTE B365M AORUS ELITE - main PCIe x16 GPU port working only in x8 width mode
      by DynaxSC
      I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
      I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
      Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
      Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
      05-04-2025, 12:08 PM
    • reformatt
      Intel iMacs, 3rd party SSD failures and Fusion setups
      by reformatt
      I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
      As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
      So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
      12-18-2024, 10:34 PM
    • Sus256
      HISENSE 65E7KQ PRO - no boot
      by Sus256
      Hi all!
      HISENSE 65E7KQ PRO
      RSAG7.820.13512 - chassis
      MT9618BAATAB - cpu
      RSAG7.820.12059 - power
      HD650Y3U77 - panel
      KLM8G1GETF - emmc
      Replaced emmc.
      Terminal log
      UART
      AC_ON
      E-B
      FDE enabled
      06-01-2025, 02:11 AM
    • cook
      HP Power Supply 6632A: Fast Mode vs Normal Mode?
      by cook
      FAST MODE vs NORMAL MODE
      I have recently acquired a HP 6632A DC power supply. I am just beginning to use it and I have been reading the manuals for it. It is the first power supply I have ever owned or used. I am a very beginner hobbyist and do not have an engineering background, as may be obvious by my question...
      I can't seem to understand what the actual use is for the 'Fast Mode' or the 'Normal Mode' on the power supply. Although the manual states what the two modes do from a engineering/technical standpoint, I don't know enough to understand what it all means,...
      06-07-2020, 05:32 AM
