Compaq PDP-121P - Baked MOV
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    #61
    Re: Compaq PDP-121P - Baked MOV
    Originally posted by socketa
    It's a long shot, but could broken stands that were going to the coil result in the power supply not getting, (and maintaining under load) enough voltage? Hence the computer shutting it down.
    Probably not.
    The DC voltages on your input caps looked good and didn't seem to drop out / dip when turning On the PSU... so I suspect this isn't the issue.
    Nonetheless, it does need to be addressed just in case. Just because I don't *think* it is a *likely* issue doesn't mean that it can't be one.
    Can i cut the yellow plastic tape, and reattach the wire to the coil? (hopefully there is no windings inside of it)
    Yes.
    Though there should be windings inside. This is the PPFC inductor, after all.
    Would it be OK to remove it (i'm guessing that it's passive PFC) and replace it with a jumper?
    Yes.
    yes but the values less 1k ohm are an issue
    Why would that be an issue?
    I've seen a lot of PSUs with low-value load resistors... hence measuring much lower resistance on the 12V rail. So I don't really think the resistance alone can tell you anything.
    Your reading should be very close or the same as the good one if both switching power supply are exactly the same model number and have the same exact ic chip on both boards
    ^ This.
    If the PSUs were the same, I'd definitely try to see why there was such a wild mismatch between the resistances. But...
    The power supplies are not the same
    That pretty much invalidates the resistance comparison... or at least as far as showing any information that may suggest a problem.
    i know that PSUs can have quite different values for minimum load resistors.
    Exactly!
    I suppose no harm in posting the resistances. Though when things measure above a few hundred Ohms on the output, then generally that means at least there is nothing wrong with the big power delivery components (i.e. rectifiers or their snubbers being shorted.) But it doesn't really amount to much of anything else. Open feedback resistors can essentially go completely unnoticed, due to their relatively high resistance value. So a resistance check on the voltage rail won't tell you if one went bad or not. This can only be found through careful component testing and perhaps a schematic or application diagram of the supervisor chip to understand what is going on.
    That being said... and recently trying out an experiment with a non-working PSU that helped me find the problem... maybe this troubleshooting trick could work here too:
    - Take a working ATX PSU and backfeed each rail into the non-working PSU, one at a time only, then power-up the non-working PSU too and see if it stays turned On.
    So for example, let's start with the 3.3V rail: connect the 3.3V of both PSUs together and turn On the working PSU. Verify that 3.3V is back-feeding into the non-working PSU. Then turn On the non-working PSU with a load and see if it can stay turned On without shutting down. If not, repeat this experiment for the 5V rail (after disconnecting the 3.3V rail.) Then do the 12V rail and -12V rail. Since the 5VSB is derived from a different circuit, don't do this experiment for the 5VSB. Also don't connect any of the signal lines on the two PSUs, such as PS-ON or PG. However, for the specific test of the 3.3V rail, make sure the 3.3V "return" / "sense" (if there is one) is connected on both PSUs. Without 3.3V sense, 3.3V rail could be off-value on one or both PSUs.
    If you do find that the non-working PSU stays turned On when one of these rails is connected, then there may be something wrong with the output of that rail on the PSU.
    The only tricky part with the PSU from this thread is that it has a 12.8V rail... so not sure if we should be back-feeding this one or just the regular 12V rail. But I suppose you could try both. Nothing should really smoke or burn, so long as both PSUs are decent brands (i.e. have good working protections.) I would avoid using a "cheapie" gutless wonder for this test.
      • Jul 2011
      • 6070
      Can you please show a hook up diagram for how you hook up the two power supply board and give more details about how to do this test correctly
      • socketa
        Asbelowsoabove
        • Jun 2014
        • 662
        • samsara
        #63
        I replaced the coil with a jumper - but no change, as expected
        So then i back-fed the 5V, and no change
        Then I back-fed only the 12V, and the computer started
        That was a nice surprise
        With the computer running, I checked the back-fed 12V rail, and it's the same as the 12.8V CPU rail, at 11.65V
        Could it be mere coincidence that both rails are the same voltage?
        (Wasn't exactly sure about what you meant by connecting the 3.3V sense wire on both PSUs - did you mean that sometimes the manufacturers don't bother connecting the sense wire on some power supplies?)
        So it looks like there is an issue with the 12V rail?
        Perhaps something 'funny' going on between the 12V and the 12.8V rails?
        • socketa
          Asbelowsoabove
          • Jun 2014
          • 662
          • samsara
          #64
          ...and perhaps it's useful to note that the resistance between the 12V, and the 12.8V, rails is 12.8kohms
          • socketa
            Asbelowsoabove
            • Jun 2014
            • 662
            • samsara
            #65
            I've traced out some of the circuitry and identified the components
            The MOSFET isn't shorted, but maybe it's still faulty?
            Could whatever it was that blew the primary side components also have damaged this secondary side MOSFET?
            Just because i could, i removed the 4 pin CPU plug from the motherboard and powered it from another PSU, but it didn't make any difference.
            So i get the impression that the problem is with the 12V rail, not the 12.8V rail
            • socketa
              Asbelowsoabove
              • Jun 2014
              • 662
              • samsara
              #66
              I tested the STP40NF03L MOSFET with the transistor tester, and it identifies it as an "N-E-MOS"
              with addional information:
              vt = 1.8V
              Cg = 2.2nf
              RDS = 0.2ohms
              Uf = 632 mV +
              Does that look OK?
              • socketa
                Asbelowsoabove
                • Jun 2014
                • 662
                • samsara
                #67
                with the theory that there is a problem with the 12V rail (that appears to be derived from 12.8V rail) ...
                would it be OK (i.e. not cause any damage) to disconnect the MOSFET and then try and start it up, to see if 12.8V comes up?
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  #68
                  vt = 1.8V
                  Cg = 2.2nf
                  RDS = 0.2ohms
                  Uf = 632 mV +
                  Does that look OK?
                  Yes, looks pretty normal. If the TT tester was able to identify it, then that means the MOSFET is actually working.
                  Looks like the MOSFET between the 12.8V and 12V rail is used either as a linear regulator or just a simple pass-through device. Check your schematic, though - I don't think that circuit can work just like that, with the Gate only connected to the Source pin via a cap. There has to be something more. In fact, if that MOSFET really is to operate as a pass-through device (or a linear regulator for that matter), then the Gate must always be higher than the Source by at least as much as the Gate threshold voltage, V_th. And for that to happen, then the Gate has to be pulled up by an external voltage source that is higher than 12V.
                  Yes, you can try that test. The 12V rail will just not appear. That being said, I suspect the PSU will not start at all with the 12V rail missing (when you remove that MOSFET), as it probably is monitoring it, along with the 12.8V rail.
                  So when you had the PSU power up OK with the other (working) PSU feeding into it, did you have that PSU's 12V rail connected to this PSU's 12.8V rail or just the 12V rail?
                  • socketa
                    Asbelowsoabove
                    • Jun 2014
                    • 662
                    • samsara
                    #69
                    - yep, thanks for pointing that out (makes sense, and i should have recognized that there was nothing, on my drawing, to turn the MOSFET on).
                    i missed a thin trace that was going from the Gate, to a 100ohm resistor, and then to pin 3 (cathode) of a KA431AZ Programmable shunt regulator, that's located on the add-on board - i'll update my drawing later
                    And i'll check the voltage at the cathode of this programmable shunt regulator.
                    Just the 12V rail
                    • socketa
                      Asbelowsoabove
                      • Jun 2014
                      • 662
                      • samsara
                      #70
                      I soldered the 12V rail MOSFET back onto the PCB and connected an analogue meter to it's gate terminal.
                      Then i plugged the rail cables into the motherboard and put the power cord into the wall socket
                      (i'm pretty sure that these Compaq computers start up straight away by themselves)
                      Then the voltage quickly rises to 5.5V and quickly drops to 3.5V, and stays there until i pull the wall plug out, and it quickly drops backs to zero after about 8 seconds (probably after the primarys discharge)
                      Pretty much the same result if i connect it to the other side of the 100ohm resistor
                      • socketa
                        Asbelowsoabove
                        • Jun 2014
                        • 662
                        • samsara
                        #71
                        Made an error on the schematic
                        Here is the correct version
                        After connecting the rail cables to ATX, CPU, and hard drive, and then plugging in at the wall:
                        Attaching a meter to the gate of the 12V MOSFET
                        There is initially no voltage
                        After a couple of seconds (i guess after the primary's charge up and the computer automatically turns on) the PSU fan clicks, and the gate voltage rises to 5.5V, and settles at 3.5V
                        If i, instead, attach a meter to where it says on my schematic "large toroid and heatsink-mounted component", the voltage rises to 4V and drops to 0V
                        So can we say for sure that there is some problem with the creation of gate voltage?
                        • socketa
                          Asbelowsoabove
                          • Jun 2014
                          • 662
                          • samsara
                          #72
                          Looks like this PSU has a crowbar circuit that's getting triggered
                          But none of the output voltages are over spec
                          The PSU runs OK with just a hard drive, but a crowbar is activated if it's plugged into any motherboard (any 5v or 12v board)
                          What would be causing the crowbar to activate?
                          • socketa
                            Asbelowsoabove
                            • Jun 2014
                            • 662
                            • samsara
                            #73
                            It would be the UC3845 main supervisory chip that is shutting this down, right?
                            probably because it senses a change to an undervoltage condition at Vcc, that is reset when the power plug is removed from the wall.
                            There is a 10uf electrolytic cap that is attached to Vcc, so maybe this this a starting cap and it provides enough energy when not connected to a motherboard, but fails to provide enough energy when connected to a motherboard?
                            Maybe it's capacitance/ESR was degraded when the surge took out the fuse and thermistor?
                              • Jul 2011
                              • 6070
                              I lost track of this post again and I just found it again and I am hoping that you figure out what is really wrong with this power supply issue is and it you can fix it or not
                              • socketa
                                Asbelowsoabove
                                • Jun 2014
                                • 662
                                • samsara
                                #75
                                I'm getting desperate!
                                I checked the rail pins of the motherboard ATX connector, in case the motherboard is faulty, but couldn't find any shorts -
                                just 11ohms on the 3.3 rail, and 15ohms on the 5v rail, so that shouldn't trigger over-current protection, because it's not even 1A
                                Then the thought occurred to me that there may be a slight possibility that i may have a similar computer lying around, so i noticed one that has a similar front bezel - its a HP/Compaq and it has a PSU with a 12.8v rail - nice!
                                So now i will be able to narrow down where the problem is (assuming that this other PSU is working)
                                I can now test the PSU safely also, because i finally made an enclosed dim bulb tester
                                I'll post my findings
                                And it's being so long, that i forgot that i tested the start-up cap (10uf rubycon YXF, which tested good) but i might try replacing it with a lower impedance/higher ripple one (33uf Samxon GF)
                                • socketa
                                  Asbelowsoabove
                                  • Jun 2014
                                  • 662
                                  • samsara
                                  #76
                                  It's definitely a problem with the 12.8V rail on this PSU
                                  That other PSU, that i found, starts up the computer no problem
                                  When i connect a 23W bulb to the 12V, rail the bulb lights up and the PSU keeps running fine
                                  But when i connect it to the 12.8V rail, which is supposed to be able to supply 7.5A (which means 96W), the PSU shuts down and won't start again until i unground and reground the PS-ON pin
                                  But it runs OK if i use an 8W bulb instead
                                  So it seems like a protective latch is being activated that is incorrectly sensing the 12.8V rail current
                                  Does that sound right?
                                  • socketa
                                    Asbelowsoabove
                                    • Jun 2014
                                    • 662
                                    • samsara
                                    #77
                                    on the secondary side, this only has two 14-pin chips:
                                    LM324 Opamp
                                    LM339N Comparator
                                    i don't know what these do, except that the LM339 might be used for OVP
                                    Any suggestion as to what to look for, in oredr to find out what is causing this PSU to latch?
                                    Would the fault more likely be on secondary side, since the PSU is not shutting down when i attach the 23W bulb to the 12V rail?
                                      • Jul 2011
                                      • 6070
                                      That might be a possibility that something is wrong with the LM339N if it used voltage monitoring
                                      • socketa
                                        Asbelowsoabove
                                        • Jun 2014
                                        • 662
                                        • samsara
                                        #79
                                        i get the feeling that it's more like an incorrect voltage (that's somehow derived from the 12.8V rail) that's being applied to one of the comparator's inputs, and hence, not creating the required output
                                          • Jul 2011
                                          • 6070
                                          This is also a possibility as well but the question is why
                                            HP Compaq Compaq SG3-240ES Compaq SG3 220 Specification for Upgrade or Repair
                                            This specification for the HP Compaq Compaq SG3-240ES can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-240ES boardview and Compaq Compaq SG3-240ES schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-12-2024, 03:44 PM
                                            HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                                            This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                                            HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower Compaq Pro 6005 B59 Specification for Upgrade or Repair
                                            This specification for the HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower boardview and Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                            09-12-2024, 03:36 PM
                                            HP Compaq Compaq dc7900 Compaq Q9400 Specification for Upgrade or Repair
                                            This specification for the HP Compaq Compaq dc7900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq dc7900 boardview and Compaq Compaq dc7900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            09-12-2024, 03:30 PM
                                            HP Compaq Compaq SG3-331IT Compaq SG3 245 Specification for Upgrade or Repair
                                            This specification for the HP Compaq Compaq SG3-331IT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-331IT boardview and Compaq Compaq SG3-331IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
