XFX pro 750 Black Edition - fan replacement
  • kleung
    • Jun 2012
    • 72
    Quick summary.
    This is a 7 year old power supply that has been used in a personal computer system under fairly low loads. As such, it's in great shape except for the cooling fan that has gotten noisy at low speeds over the year.
    I was contemplating replacing the PSU as it uses a fairly uncommon 135 mm fan but in the end; found a solution. Also, it uses a psu standard 2 pin power adapter which is equally uncommon.
    120 mm Bequiet Silent wings fan -1100 pwm
    3d printed mount adapters (can use zip ties I suppose)
    The fan was able to be mounted in the PSU and I ran the power /control cable out the back with the non-modular power lines to be controlled by a motherboard fan header.
    Quieter and better than before.
    I don't mind paying for upgrades but this psu still seems to be in excellent shape otherwise and it would be a shame to discard.
    Just putting this knowledge out there in case...
    • 31086
    Re: XFX pro 750 Black Edition - fan replacement
    strip & lube the fan, it's only held together with a plastic split-washer
