Re: Manson NP-9613
Could it be this one is the cause ? When I tested ESR=1.5 Ohm Caps = 5400uF, suppose to be 4700uF
Manson NP-9613
Re: Manson NP-9613
I have replaced both on the blue box, no luck yet ?
Re: Manson NP-9613
I've replaced both 2N3904 and TL431, no luck, yet,
could it be a relay issue ? thanks
Re: Manson NP-9613
Right under that cap. You are on the left of it.
Re: Manson NP-9613
Originally posted by R_J View PostThe transistor next to CN4 also looks bad, compare that transistor to Q7 and you can see Q7 has the spot along the molding line which is normal but the transistor next to it looks like it is damaged at that point
I saw it, it's blown isn't ? after zoom ...Last edited by bianchi77; 11-25-2019, 05:27 PM.
Re: Manson NP-9613
Re: Manson NP-9613
looks like there is a bad transistor next where VR8 is written on the board?
Re: Manson NP-9613
Originally posted by CapLeaker View PostWe need pics to see what you got!
Is it hitting a cc cutoff or what are the testing conditions?
I got one burn zener diode and replaced it,
could it be TL431 or relay is broken ?
Manson NP-9613
Dear Members,
I have an issue with Manson NP-9613,
Everytime the voltage hit 19V, the relay is switching and voltage is going down,
What is the issue ?
ThanksTags: None
