I have a asus power supply that with a load , drop from it's nominal voltage to 16 V. I haven"t a schematic so my question is: it makes sense to open it, it's an easy fault to detect ?
Asus switching drop
Tags: None
Re: Asus switching drop
Hi, thanks for replay. I have opened it and I have desolder all six 1000 mF caps in the output stages, no sign of faul externally, I have measured them with a meter and all have the nominal capacity. I read that it's possible that there is a fault even the capacitance is correct and they must be tested with appropriate equipment, it's right ? I have a mega328 component tester and I will try to check them with it to find more data (but this isn't a professional equipment)
I'm checking all resistor and non electrolitic caps but I don't know if this can help to solve this issueLast edited by jasko_jacker; 10-24-2019, 08:01 AM.Comment
Caps test:
WCO Vent LoweSR 01/19 1000 mF
1 - 997 0.8 Ohm .5%
2 - 985 0.4 .5%
3 - 1005 0.8 .6%
4 - 1007 0.6 .6%
5 - 1007 0.6 .6%
6 - 973 0.5 .8%Comment
I'm very sorry, I repeated the mesurement and about the electrolitic capacitors I made an error to report values,
the measurement are 0.0X .
I'm studying recently how the smps works but
I think this is a very simple circuit, TL431,BJT,Zener,resistor and capacitors to
drive the optocoupler to provide a feedback.
I have tested individually each component of the
cold part of this power supply and I have only a dubt about tl431 that I test only with a meter in diode mode and not with a test circuit.
When I connect a load, on the anode of tl431, the voltage drop
from 2.5 V to 2.0 V it should be insufficient to operate this shunt regulator. Without a load the voltage remain stable to 19V. If I remove the load the voltage not return to 19V
Can I increase the capacity of C6 or replace it (I repair notebooks so I don't have this type of spares), could this component be the problem?
I still have to test the optocoupler by unsoldering it. But with a tester and i place
I think it's okAttached Filesif you find these attachements useful please consider making a small donation to the site
I have removed the NPN, and without it seem that the voltage is stable.
After that I substitute it (1AM) with BC846 but the drop returns.
I have no experience with oscilloscope and I have avery entry level usb unit
but I connect ch1 with opto IN and ch2 with opto OUT.
It's a case that the voltage remain stable without transistor ?Attached Filesif you find these attachements useful please consider making a small donation to the site
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...09-07-2024, 02:50 AM
This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...09-07-2024, 02:50 AM
This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-07-2024, 02:50 AM
This specification for the ASUS ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year boardview and ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...09-07-2024, 01:30 AM
- Loading...
