big-220volt or small-12/5/ volt caps?
  • montanglo
    • Jul 2009
    • 14
    PC m.board resets guess due to faulty supply(works ok with a new though stronger supply) so which caps to replace first?(visually all look ok)
    tnx
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    Re: big-220volt or small-12/5/ volt caps?
    Brand/model of psu as well as brand of capacitors in it.
    Pics would be helpful, may not be caps that are bad.
    • yanz
      • Nov 2004
      • 910
      yup, pics would be helpful. and check the voltage on all rails to see if there's any indication of failure in psu components..
      • montanglo
        • Jul 2009
        • 14
        it is a regular no name supply another manifestation is if it does not work and reset than it would not put graphics on monitor at all
        Vacuum cleaned it inside as well as the m.board-no help , you suspect some supply /mobo transistors or regulators ?
        • 370forlife
          Large Marge
          • Aug 2008
          • 3113
          Still a brand of psu would be nice, as some psu's can be good just not like the motherboard.
          My friend has a really nice 700W delta power supply that he runs with his EVGA board, but he can't shut it off or he has to plug in a different power supply then take it apart and put the delta back in for some reason.
          Anyways, capacitors can go bad without visual signs, but we need a better description of the problem. So you will just be doing something and it suddenly resets itself?
          • montanglo
            • Jul 2009
            • 14
            well first noticed supply runs but mobo would not put graphics to monitor then opened both
            and Vacuum cleaned now PC sometimes works until it resets ater you start a major hdd operation , and then works for a minute until another reset..
            with another supply everythng ok
              master hoarder
              • May 2008
              • 12175
              Well there should still be sticker somewhere on the power supply. Just take it out of the computer and look for it. Also pictures would be really helpfull.
              Reason we ask you for brand/model and pictures is because the PSU might not be that bad but it just could be that the capacitors in it have gone bad. But if it's a bad power supply, new capacitors won't help it.
              • montanglo
                • Jul 2009
                • 14
                ok I ll have a look but it worked flawlessly for years
                  by momaka
                  03-12-2025, 03:42 PM
                • GraphicMan
                  rio volt portable mp3 cd player.What type of caps are these?
                  by GraphicMan
                  Hello
                  this is a rio volt portable mp3 cd player main board
                  accidentally its 120ac power adapter was used with 220ac
                  the unit worked for few seconds and then off and never worked again
                  it normally takes 3volts batts or 4.5dc from the adapter socket
                  in the picture I believe this is the main power IC (4 channels)
                  it is the only area in the board that barely gets warm after few minutes
                  drawing 0.4 watts in total continuously
                  i did checked all the caps on the board including these caps around the IC
                  nothing is shorted...
                  09-11-2022, 07:52 PM
                • eryjus
                  by eryjus
                  05-10-2023, 11:21 AM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
                • captain150
                  by captain150
                  03-16-2025, 07:34 PM
