Compaq Contura laptop PSU output is high
  • ckrtech
    • 113
    OK, guys. This one should be fun and out of the typical ATX zone a bit!
    This is a power supply for a 486 Compaq laptop. There are a couple of issues
    1: There is a bit of an open in the power cord. Tough to get a reading from the barrel, but when I do...
    2: The output is around 22 volts.
    The Max output is apparently supposed to be 18.5v according to the casing.
    Now I suppose I could try to repair the open to get a stable "22v" at the barrel connector and plug it into the laptop - and goodness knows the condition of the laptop - but I was hoping maybe you PSU guys could share some thoughts on this little guy.
    He is about 24 years old.
    The component bolted to the heatsink to the right of the transformer (output side) with label CR3, I can't quite make out. It looks like:
    30
    892M
    -> <- (couple of diode arrows point at each other)
    master hoarder
    • May 2008
    • 12170
    • Bulgaria
    Re: Compaq Contura laptop PSU output is high
    What series are those Nichicon capacitors? PR? PL?
    Old Nichicon PR caps like to leak from the bottom and cause all sorts of issues.
    That said, the 22 odd volts you read at the output may or may not be an issue. I've seen numerous genuine "18.5V" HP adapters read 19.5-20V before and it wasn't a coincidence - they were designed like that (or most likely re-labeled 19.5V adapters). I doubt your laptop will have any issues with 22V, as the caps at the input inside the laptop are usually rated at least 25V (the next lower value is 16V, but that wouldn't be any good for an 18V adapter).
    So first check what series of Nichicon caps you have. If not PR, then fix the open-circuit issue with the barrel and see what voltage you get from the adapter. Then see if it can power on the laptop. It looks like a well-built power adapter, so it is likely to be okay, even with the caps being this old.
    • jazzie366
      • May 2016
      • 304
      Nichicon PL do this as well.
      I second this, also depending on the regulation that voltage may drop with a load.
      Popcorn.
        HP Compaq Compaq SG3-240ES Compaq SG3 220 Specification for Upgrade or Repair
        This specification for the HP Compaq Compaq SG3-240ES can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-240ES boardview and Compaq Compaq SG3-240ES schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
        09-12-2024, 03:44 PM
        HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower Compaq Pro 6005 B59 Specification for Upgrade or Repair
        This specification for the HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower boardview and Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
        09-12-2024, 03:36 PM
        HP Compaq Compaq dc7900 Compaq Q9400 Specification for Upgrade or Repair
        This specification for the HP Compaq Compaq dc7900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq dc7900 boardview and Compaq Compaq dc7900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
        09-12-2024, 03:30 PM
        HP Compaq Elite Compaq Elite 8300 Small Form Factor PC (ENERGY STAR) Compaq Elite 8300 i3-3220 Specification for Upgrade or Repair
        This specification for the HP Compaq Elite Compaq Elite 8300 Small Form Factor PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq Elite 8300 Small Form Factor PC (ENERGY STAR) boardview and Compaq Elite Compaq Elite 8300 Small Form Factor PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
        09-12-2024, 03:28 PM
      • FrancescoV
        Onkyo HT-R390 no sound output, video output ok
        by FrancescoV
        Good morning everyone,
        I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
        The firmware reported is the following:
        M:1.00/11107BLP
        D:?.??/????????
        O:1.00/11107AL
        The DSP firmware given the question marks seems corrupt.
        On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
        05-11-2025, 02:59 AM
