PSU capacitor reference thread
  • Leopard
    • Mar 2008
    • 109
    • Finland
    Of course there are plenty of other factors which affect PSU build quality, hence we have the PSU Build Quality pictorial & discussion threads, but since this site is mainly about capacitors I think it would be a good idea to put up a thread with reports of the caps that different PSUs use. Just post the latest sightings of caps in PSUs you had to maintain or open to check the capacitors.
    LW-6500HDP V2.2 (Huntkey)
    Input: Teapo
    Output: Teapo & Fcon
    FSP250-60GTV (PF) (Fortron / FSP Group)
    Input: Teapo
    Output: Teapo, Fuhjyyu, Jamicon
    Keep 'em coming!
  • MORETTIGIAN
    by MORETTIGIAN
    Title:
    Description:
    Procedure performed:
    - Removed backplate
    - Reapplied thermal compound
    - Reassembled card
    09-18-2025, 12:14 PM
  • devsigner
    identify capacitor for MacBook Pro with rare logic board 820-02037-06
    by devsigner
    Hi
    While messing around with my MacBook Pro, I stupidly pinged off a very small surface mounted component that I’m now trying to identify.
    resistance tests show a rising resistance value, indicating a capacitor.
    The laptop boots up and runs, however I'm choosing not to use it until I get it fixed.
    i can’t see any markings on the capacitor at 10x magnification using a professional jewler's loop.
    It seems like there's some damage to the capacitor - one side doesn't have "shiny bits" - can you tell I don't do this for a living!...
    Yesterday, 01:39 PM
  • Prolog
    by Prolog
    12-01-2024, 08:27 PM
  • Agent24
    Dick Smith Q-1760 linear power supply filter capacitor question
    by Agent24
    I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
    It has at least one problem.
    The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
    I have already ordered a replacement potentiometer, so that's not an issue.
    Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
    All are CapXon...
    10-21-2025, 05:39 PM
  • chth96
    by chth96
    12-22-2023, 04:34 AM
