HiPro HP-D250AA0 HPD250AA0 PSU Buzzing In Standby
  • jay007
    • Jul 2008
    • 15
    Has anyone had any joy silencing these supplies?
    I don't know if they buzz from new but glue on almost every through hole component do not ooze any confidence.
    If i put a wooden chopstick like stick on C806 (picture 4) the buzzing gets noticeably louder without having to put your ear on the stick.
    Now i don't have any schematics or do i know enough about PSU design to work out what value it should be so i changed all the through hole diodes and the standby cap but not the 2 little caps on the left side of picture 3 and the buzzing continues.
    R803A, B and C all test ok @ 33k and R801 @ 100k
    Other than the 2 small caps on the topside that i have not yet changed where do i go next?
  • jazzie366
    • May 2016
    • 304
    Re: HiPro HP-D250AA0 HPD250AA0 PSU Buzzing In Standby
    Is it just me, or is there a wire/component lead sticking through the joint and touching that cap you mentioned? It also looks like there is a minimal amount of solder on that joint, try reflowing it?
    Popcorn.
    • tvguy12012012120
      by tvguy12012012120
      02-07-2025, 05:13 PM
    • silberdrache
      Burnt Hole under IC on MacBook Pro M1 Pro 14"
      by silberdrache
      I'm new to this Forum, so I hope it's the right place for this topic.
      Im a student from germany, and as a hobby I repair electronics. I started microsoldering maybe 1-2 years ago.
      I have a MacBook Pro 14" m1 Pro with 10 Cores and 16/1tb storage. The board Number is 820-02098-A.
      The MacBook has a light water damage. Coffee got spilled over it, but the Mac continued working only the battery didn't charge anymore and when the battery was empty the Mac turned off and doesn't show any sign of life now.
      I opened it up and there were only three drops of coffee...
      11-10-2025, 11:19 AM
    • fharris1977
      Vizio D50u-D1 Dead Set No Standby
      by fharris1977
      Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
      12-28-2023, 10:25 AM
    • Crystaleyes
      Samsung BN44-00259A standby question
      by Crystaleyes
      Hi all.
      I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
      SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
      Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
      The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
      08-11-2023, 05:15 AM
    • psssst
      Yamaha TSX 120 Standby Problem
      by psssst
      Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
      03-01-2024, 07:25 AM
