Re: Junk Fu or not Junk Fu ...
Ah, it's that strange package…never been sure if that's actually standard, or custom. Much like other specialities, CU6808X and so…
Thanks Behemot!
I suspect that in this particular case the suffix letters may make a difference. The CM6805(A;B)/CM6806A in your pdf are 10-pin SOIC:
Unlike the CM6805BSX or CM6903A, that are 9-pin SIP:
CM has the datasheet on their website (they only list the basic version each time, e. g. CM6805, without all the other letters which most likely specify package and materials). I have a copy http://www.hwworld.cz/files/Datashee...cro/CM6805.rarLeave a comment:
Addendum - Fine tuning VReg
The +12V voltage was still a bit low for my taste, beginning at 11.95V when PSU was idling (out of comp, no load, just jump-started) and dropping to ~11.7V @ ~250W load ...
so I investigated about what could be done on the subject.
In this PSU the PFC/PWM controller is a 9-pin CM6805BSX, of which I can't find a datasheet.
However a did find a datasheet for the CM6903A, which is also 9-pin and looks very similar. Scrolling down you can find this application circuit ...
As it turns out, CWT GPA uses a similar circuit for voltage feedback and regulation ...
So I replaced the 39.2K resistor with a 0~47K potentiometer ...
And adjusted the pot with a screwdriver to fine-tune the voltage regulation to my liking ...
Now the PSU idles at 12.25V and drops to ~12.0V @ 250W.Leave a comment:
^ Very interesting and enlightening: http://www.hardwareinsights.com/wp/c...esign/7/#Bonus
I think I've even squeezed 25mm one in there, as I always have something laying around from other units I've replaced caps before (or ditched as bad), no need to buy them. These sausage-caps don't come cheap…Leave a comment:
Yep did some thinking on replacing the bulk cap.
The OEM Elite is 22x35mm. In GPA there is very little if any room for a wider cap, and height clearance is ~50mm before cap sticks its head in the fan.
There is a nice series from Rubycon that comes handy when parking slot for bulk caps is tight: MXK.
One could squeeze a MXK can of 22x50mm with 390uF 400V, or 330uF 420V / 450V.
But ultimately I chose to leave the Elite, for this PSU will power up a ~200W tops office comp lacking discrete GPU, so low uF ain't that critical (though higher voltage rating and a more reliable jap brand wouldn't harm longevity).Leave a comment:
I am first getting some new low-ESR Rubycons for PSUs, have just payed the proforma invoice this week, but the Suncons are next (in about four months from now). Wanna get 1800/6.3 D8 and 1500/16 D10 first, don't have these or any similar on stock. It is not the lowest-ESR series, being cross-reference to KZG and MBZ, but the best available today, and still OK even for Vcore. And it is also interesting that they state longer than usual endurance, 1000-4000 hours, where most of the ultra-low ESR series only stated 1000-2000 hours.
Even for 350 W version 180uF cap is too low and does not even provide hold-up time in spec. There is little space but with some effort you may be able to squeeze some tall versions of 330uF in there (I did), with that the HUT increases to about 14 ms. I did not check efficiency but the experiment with Corsair CX550M suggests these platforms may actually even get better efficiency if you increase the capacitance.
If you mean the bulk cap, I left the OEM Elite GM 400V 180uF 85C. Rachitic in size but should do for the application.
.Leave a comment:
Yes they do, I plan to stock some by the end of the year. It is the last ultra-low ESR series still being made.
As such it is not much intended for SMPS.
What cap did you put after the PFC?Leave a comment:
From what I saw they don't, but who cares if it work alrightLeave a comment:
I don't think so. It's a 'vintage' one, but in good health.Leave a comment:
PSU works fine with 2.2uF Panny FCs in place of 1.0uF Junk Fus. No explosions.
BTW voltage regulation is much better after fitting real caps (Panny FC/FM/FR of 2200 & 3300uF) than with the original manure (Junk Fu WG/WL and Su'scam SD of a rachitic 1000uF).
Interestingly the only two decent caps that came OEM with this PSU are the bypass cap for the TNY176PN +5VSB PWM controller (Chemicon KY 50V 10uF), and the first +5VSB filtering cap (KY 16V 1000uF 8mm).Last edited by TELVM; 02-14-2017, 10:24 AM.Leave a comment:
It's a CWT GPA platform inside an Antec VP-400PC.
I think I'm going to replace the 1uF Junk Fus with the 2.2uF Panny FCs and see what happens.
.Leave a comment:
It's weird, I guess it's just where the caps are placed. The Jun Fu's I've encountered were in a pretty expensive analog TV box. The thing when new was probably 50-100$, but was pretty small. Worked well though, never had a problem. It never really got that warm either, so maybe Jun Fu's just don't like heat?
Who knows, I guess it's all situational. But I don't judge caps by brand, I judge them by experience and reputation.Leave a comment:
Must say that almost all the gluxon and teapo that I have saw are in good shape and on working boards or that are damage but by other things, not caps, capxon/jun fu/G.I/KZG have failed to me almost everywhere I found themLeave a comment:
I'm kinda iffy about Jun Fu caps. I've had some rather interesting experiences with them (and a lot of other caps) that made me reconsider a lot of the "junk" caps.
I have a Bob Carver Sunfire True Subwoofer MKII and it is enirely capped with Jun Fu capaitors. None failed except for two which were too close to the 2700W amplifier fets that of course, got quite warm. The thing is though, all the other board caps are in fine shape and the amplifier sounds amazing after putting two Nichicons in place of the bad caps. Closer inspection revealed the caps had dried out from heat and shorted, causing the failure. Other than that it has no problems and sounds crystal.
I also had a TV box that was at least 10 years, probably more old that was made by Magnavox. It was given to me by my grandmother who thought I could still use it, (and as a kid, I actually did use it for a short time). After that, I found it again many years later, opened it up and same story. All Jun Fu caps, except none were failed or even showed signs of failure.
So that led me to believe Jun Fu's are like CapXons, keep them inside of their spec and except for a few bad series they're not terrible capacitors compared to things like Chong, which all of which I've come to encounter don't vent at all they either explode or blow their bungs out.
So personally, if the cap is just a turn on cap, or something that's just going under minuscule load, leave it it'll probably be fine. If it's a secondary cap on a shitty PSU that's probably running it out of spec, then replace it (if it hasn't gone bad already).
By the looks of the pic, there are more than just those Jun Fu's on the board, I see some on the output and the main filter is one.
Your choice, you can recap it all or leave the smalls.Leave a comment:
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by eryjusHello,
Channel: General Capacitor Questions & Issues
by Paxman_SwedeHello!
I have studied the board and...-
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
- Loading...
