SPI ATX 350w refurbish
  • pentium
    • Mar 2006
    • 2778
    Normally I'd look for another power supply but I'm extremely short sources on where to find another PSU right now so I have to make a compromise.
    AT form factor high wattage power supplies are hard to come by these days so I'm grabbing a cheap low wattage ATX power supply and making that work.
    I pulled an SPI 350W rated (probably 250w) ATX supply out of an untested Pentium D machine. Now that I have it on he bench I can tell that the lone 16v 3300uf cap is bulged and the remaining 10v 3300uf and 10v 2200uf are TEAPO, so it's safe to say they'll need to go as well. First issue is all I got are Panasonic 16v 2200uf caps. I know normally it's not a good idea to use lower value caps but this thing is going into a less demanding system (300 peak max) so will it be fine?
    Second is that with PWR_ON grounded and a hard drive plugged in as a load the thing sqeals like a madman. The +5 and +12 are nice and stable and +5 has 4mv AC ripple but +12 has 128mv. That doesn't seem right. Should I assume the squeal is attributed to the extremely high ripple, not enough of a load or simply it being a crappy Sparkle?
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
  • kaboom
    "Oh, Grouchy!"
    • Jan 2011
    • 2507
    Re: SPI ATX 350w refurbish
    get the teapos outta there!
    the panasonics will be fine for testing- don't run it to full load
    don't forget those teapos, being rather questionable, may have only been 2700u, especially if they're rather compact
    load it with lamps or resistors to the approx demand of the system it will eventually power, then scope it and examine the ripple
    if you're attempting to measure ripple with a DMM, those won't read high freq AC too well- if that's the case, ripple will usually be higher than indicated
    the squealing isn't ripple per se; it's the feedback loop oscillating
    replace all caps including small ones (you already know this) and recap the aux supplies
    don't forget the two 2.2-4.7u/50v caps in the base ckts of the two switching transistors, if it's a half bridge.
    "pokemon go... to hell!"
    EOL it...
    All style and no substance.
    guilty,guilty,guilty,guilty!
    guilty of being cheap-made!
    • pentium
      • Mar 2006
      • 2778
      Yep. After I replaced the caps I DID have in stock I loaded down the rails and it powered up with no squeal and already a lot less ripple. This is indeed a candidate to complete the rebuild.
      Find Nedry!
      • kaboom
        "Oh, Grouchy!"
        • Jan 2011
        • 2507
        1. Get the caps off the load resistors.
        2. Return the low side common from the load to the common (black) wire(s) from the output of the supply, not to the chassis of the unit under test.
        3. Connect scope probe gnd to case of PSU and probe tip to an unused wire from the same rail (under test) you want to measure:
        You want to measure ripple on +5. Connect load between one of your red wires and any black wire; connect probe tip to one of those red wires which does not have the load attached. Again, connect scope gnd to case. This puts scope gnd/common very close to the secondary common of the supply under test, and also puts the probe tip very close to the rail whose ripple you want to measure; you use one of the unloaded red wires (in the case of +5) as a "jumper" to go directly to the output of the supply.
        You also never connect the scope common to the return wire of the load at the load; here you have common potential rise, leading to common mode currents up the scope probe shield. That current goes thru the scope case, up the third wire of the scope, down the third wire of the PSU's line cord, and back to the secondary low side. This is an unwanted parallel path for testing; remember, this is secondary current (with ripple) going up your scope cable. Any AC component will couple into the center conductor. Depending on phase, it can give false indications of greater or lesser than actual ripple.
        The scope common must go to the lowest point on the secondary- either the case or an unused/unloaded "black wire" with a computer SMPS.
        In order to truly measure ripple, you cannot have any resistive elements (like loaded wires to resistor banks) before the point where you pick the sig off with scope.
        See example:
        M2= ripple at supply
        M1= ripple after being shunted by filter consisting of test lead/clip resistance (R1/R2), load resistance (R3), and the "lying capacitor" (C1) across the load
        M3= DC return potential rise- results in current up the scope probe cable shield
        M4= AC return potential rise- also results in current up the probe cable shield, but being AC, couples into the signal wire! A recipe for misleading/false "safe" ripple indications.
        All wire has resistance, and so has voltage drop while carrying current! This is true both at the load end of a "supply" wire, as well as at the load end of a "return" wire! See M3 & M4 again- the low side of the load is not at GND potential, but actually higher!
        EOL it...
        • pentium
          • Mar 2006
          • 2778
          Those are the Panasonic 2200's. You literally just told me doing this for testing was fine.
          You can't see it but there's two yellow wires. One shorts PWR_ON to the chassis and the other is +12.
          I already did the ripple check again and things have improved even with the wrong value caps.
          I just wanted to follow-up.
          Find Nedry!
          • kaboom
            "Oh, Grouchy!"
            • Jan 2011
            • 2507
            No, that's not what I said at all.
            One- I never specifically said to put them across the load resistors- the diagram shows what will happen.
            Two- "try these caps for testing" means to solder them into the unit in question, even if temporary to evaulate how it responds, as has been done here and elsewhere.
            I don't know how you made that leap; it doesn't even make sense to do that, especially while leaving the old ones in place. Should've pulled the board, pulled the 3300/16v teapo, and whichever teapo on +5 before the pi choke, and replaced/subbed both with one of those panasonics.
            EOL it...
            • PeteS in CA
              • Aug 2005
              • 3586
              • USA, Unsure of Planet
              Sparkle isn't crap. MAYBE not as good as Delta or Lite On, but ...
              Anyway, being rated for 350W it might be 10 years old or older. Even the best electrolytics have a finite life. Probably some of the O/P caps were high impedance, resulting in oscillation and high O/P ripple. That's why installing good caps fixed the squealing. I'd still get some good, proper value, caps for the rebuild (maybe Nichicon PW or PA series, or similar?). If the P/S is >/= 10 years old, the fan may be worn or worn out. Depending on the currents you need, uprating (as needed) to rectifiers rated for at least 30% higher than the needed current would be a good idea.
              PeteS in CA
              • AJ847.63e
                Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                by AJ847.63e
                Hi Folks,
                Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                05-06-2025, 10:37 PM
                HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                09-12-2024, 02:20 PM
                HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook 1000 Specification for Upgrade or Repair
                This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                09-06-2024, 10:56 AM
                HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
