PSU no start on some PCs, ok on others
  • sleepydog
    • Feb 2008
    • 7
    This is not the same PSU I mention in my other thread, it's from an old Shuttle Athlon XP, 200W Achme thingy. It appears:
    1. half dead (motherboard LEDs come on, but nothing happens when pressing the power button) on these machines:
    - Athlon XP 1.4GHz
    - Athlon XP 1.8GHz
    - Pentium 4 3.06GHz
    2. perfectly alive on:
    - Celeron 600MHz @900MHz (ancient overclocker, how I loved it!)
    Considering that it starts only the weakest machine, I'd say that it just can't produce enough juice, whether on the main rails or the standby rail.
    What do you guys reckon?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: PSU no start on some PCs, ok on others
    bad caps.
    acme+shuttle=bad fuhkkyu caps.
    a friend has a cluster built out of 50 of the shuttle shoebox pc's
    i have recapped all psu and mobo's...after only a year in service.
    • kikkoman
      • Jul 2007
      • 691
      you already said it.
      it's simply too weak for those machines.
      i strongly doubt that it's capable of 200W and probably it has bad caps, too. ----> toss it.
      i managed to run an athlon TB 1.4 (~70W) system with a 120W PSU once, but that was a FSP unit. i guess it pumped out a bit more than 120W.
      "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
      • gdement
        • Jan 2007
        • 690
        If it was part of a complete package, then it may have been optimized for the load requirements of a particular motherboard. It may be fine on a certain Athlon board, but not provide any headroom to just work on any random motherboard you plug into it.
        • sleepydog
          • Feb 2008
          • 7
          You'd think that, but actually the Athlon 1.8GHz is the Shuttle the PSU came with. Today I opened it up again, and this time I noticed a few bad capacitors (one leaky, 2-3 slightly bulged), so kc8adu, you got it there (and they are indeed Fuhkkyu, the bad ones are 1000uF, 10V, black - don't know color codes or anything).
          Any suggestion on a reliable substitute?
          • starfury1
            • May 2006
            • 1256
            well I don't know the psu off hand and others are far better to give a definitive answer on this.
            although a colour code does exist for polyester type caps "green caps" another common name (or orange drops) is more commonly what you see
            I don't think it has been used in years...could be wrong..well not real popular if it is still being used.(they are less then 1uF in value too non polarized...no +-)
            (really the above is for clarity rather then saying they don't exist)
            With "Electrolytic capacitors" its usually marked on the can.
            The capacitance Value UF and the
            Working Voltage also the
            Series of caps and usually
            who made them (this may take the form of a logo only)
            The important thing is if they are "DC filtering Output caps"
            they must be Low ESR types
            This is possibly one of the few times you can actually go down in "voltage" with a capacitor...normally NEVER do this
            the caps are "1000 uF 10V" you can use (provided they are on 3V3 5V rails) 6V3
            12 Volt rail will probably have 16 volt caps
            So 1000uf 6V3 Low ESR caps are what you need to buy
            Such as Panasonic FC's there are a few that would do the job...example only
            just a few guidelines on recapping
            first question, is it actually worth recapping...some psu's are hazards to start with
            normally the problem is space, a lot use thinner (8mm I think) caps
            and getting these in a quality cap can be hard.
            I think Samaxon make suitable caps in this size.
            You can if you think they will fit use larger diameter caps
            but this will depend on the actually supply layout
            sometimes you can shoe horn them in even if they sit a little high
            I'll leave it to those that know
            if it worth recapping and what would be best suited
            or try searching the posts, there's a fair chance this psu has been posted on before.
            with MB and PSU use the right caps...what you get at hobby stores will not cut the muster with most caps that fail with these.
            TC forum owner can supply suitable caps and he knows the issues so it worth a PM if you don't want to stuff around
            but its up to you what you want to do
            HTH cheers
              SHUTTLE XS 3600BA D2700 Specification for Upgrade or Repair
              This specification for the SHUTTLE XS 3600BA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XS 3600BA boardview and XS 3600BA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for SHUTTLE XS 3600BA...
              09-12-2024, 03:44 PM
              SHUTTLE XPC nano NC1010BA XPC nano 4205U Specification for Upgrade or Repair
              This specification for the SHUTTLE XPC nano NC1010BA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC nano NC1010BA boardview and XPC nano NC1010BA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-12-2024, 03:36 PM
              SHUTTLE XPC nano NC3000BA XPC nano 3865U Specification for Upgrade or Repair
              This specification for the SHUTTLE XPC nano NC3000BA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC nano NC3000BA boardview and XPC nano NC3000BA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              SHUTTLE XPC nano NC1010XA XPC nano 4205U Specification for Upgrade or Repair
              This specification for the SHUTTLE XPC nano NC1010XA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC nano NC1010XA boardview and XPC nano NC1010XA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              SHUTTLE XPC slim DX30 XPC slim J3355 Specification for Upgrade or Repair
              This specification for the SHUTTLE XPC slim DX30 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC slim DX30 boardview and XPC slim DX30 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for SHUTTLE...
              09-12-2024, 03:30 PM
