external/brick LCD power supply whine, annoying, but only in standby
  • rancur3p1c
    • Mar 2015
    here's an FFT analysis. It's pretty noticeable from 10 feet away in bed [click box link to view image]:
    https://app.box.com/s/e97vfzs2h0ascf7o5uy8bof4hwhpckym
    Brand new with QNIX QX320QHD. I could:
    1. contact seller for another one. Will the new one have problem?
    2. find another 6a12v supply from a reputable source (where do I find one of those?)
    3. disassemble and stick shoe glue on all the transformers/caps? I don't konw how to crack it open though.
    4. [preferable/easiest] build a sound deadener thing out of an old amazon/newegg box and some cheap home depot foam. can give breathing room, but still worried about a bit of heat ....
    Make/model is SAWA-02-600, like this one: http://www.aliexpress.com/item/Sanhu...013102233.html
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: external/brick LCD power supply whine, annoying, but only in standby
    Easiest solution would be to add some minimum load resistors. It will burn a bit of extra power but will get rid of the noise. The power brick is poorly designed and oscillates with low or no load, hence the whine.
    A working TV? How boring!
    • rancur3p1c
      • Mar 2015
      so it already idles at 7w-- or at least consumes 7w-- instead of the 0.5w standby that it's supposed to be. You think more would help? Also, I am handy with glue just stick it in there, but I wouldn't actually yeah I would. Nevermind. But still, it already uses 7w at idle, so...
      it does have 2 screws under the rubber feet on it, I'm hoping it's a clamshell that I could easily crack open and not bonded/plastic-welded shut
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Is that 7W idle with the brick plugged into the monitor? If not, that doesn't seem right at all. It might be fooling your power meter.
        -Ben
        Muh-soggy-knee
        • Khron
          • Sep 2006
          • 1350
          • Finland
          And where were those 7W measured?
          Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
            • 31246
            sealed bricks are an oven, it may have bad caps in it.
