Samsung plasma psu
  • leonard
    Leonard085
    • Aug 2010
    • 10
    • Ireland
    Samsung plasma psu
    I have a psu pcb that the vs and va voltages shut down after about 3 minutes working
    I checked for poor solder joints, all ok
    psu pcb type BN44-00442B
    has anyone got a schematic?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Samsung plasma psu
    resolder everything mounted on a heatsink or that gets hot.
    • Panzer_green
      • Aug 2014
      I have a samsung plasma too (ps51d6900dm) turning on issue.
      The problem is the tv turns on and gets to the logo but then turns off! tries 3 times and for safety reasons stops trying to turn the tv on i believe.
      I did a few checks and by no means am i very knowledgeable when it comes to fixing tv's but i checked all my voltages and they seem to be fine and disconnected other boards yet still came to the conclusion its the power supply.
      I then heard about heating the board with a hairdryer to see if it turns on! which it did turn on. So i isolated it to a part of the board and found when i pushed on the IC the tv stayed on when not heated. I then believed it was a cold solder joint. It worked after re soldering this area for a week! then the same problem happened again! Is this part likely to be causing this problem and if so where can i get this part as i have had no luck looking myself!
      Photo of IC i believe is faulty! in link
      http://www.avsforum.com/forum/attach...7&d=1408930516
        09-07-2024, 05:50 AM
      • Egidio85
        Samsung UE55F8000SZ Turns on and off immediately
        by Egidio85
        good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
        This defect happens continuously, hearing the classic click of the relay every time.
        Power supply board BN44-00636B
        disconnecting the mains and lamps from the power board always causes the same problem.
        Is it normal that without anything connected this power supply turns on and off cyclically?
        any suggestions on what to check?
        thanks in advance
        03-11-2025, 12:45 PM
        09-06-2024, 11:40 PM
        09-06-2024, 08:40 PM
