APC Smart-UPS 3000 XL (SUA3000XLI) not reading voltages well
  • camisao
    • Jan 2024
    • 11
    • Portugal
    Hello there,
    I have a issue with a tower UPS 3000XL with also an external battery tower that has almost new batteries and very little use.
    A week ago it started entering boost mode because the read line voltage was below 210VAC, when it was in fact near 225 VAC.
    The battery voltage was also low (48 or 49), when in fact the batteries are fully charged to 55.1 VDC.
    I opened it up up, cleaned and tried a reset.
    I updated lower transfer voltage to 196 with apctest and then used the serial port to adjust the configuration with a terminal in Prog mode to try to get line voltage and battery voltage reading identical to a voltmeter.
    I managed to get the line voltage ok, but the battery voltage constant is already FF and the maximum I get now is 46.71 VDC...
    Could this be a hardware issue? Is there a way to clear everything and try to configure again?
    I tried to look for the schematic, but some links are dead.
    Thank you for your support.
  • hcs77
    • Mar 2017
    • 4
    • Hungary
    At first please replace the low value capacitor first, then the big vales, because the 22uF dryes out over time and causes serious problems. Use good brand low esr capacitor if possible. Higher voltage not a problem.
    Please remember these devices works 168 hours a week, 10 year online means 87600 work hour.... Elektrolit capacitors has a limited lifetime. Change the 1uF X2 capacitor and the 300V 20mm varistor at the input. Safety.
    If the capacitor change does not solve the problem, check the voltages, especially 78005 (7805 1% version).
    Search for the pcb number on the internet (640-xxxx), hope you can find a schematic for it. If you can't find anything you can use the SU2200 schematic for reference, designed at the same company, similar enough for help.
    Good luck.
    • camisao
      • Jan 2024
      • 11
      • Portugal
      Hello hcs77,
      Just sending an update.
      I found a schematic in a Portuguese forum of a different model (SU2200/2200XL/3000), but used it as reference, as it look identical.
      I opened the UPS again and checked some of the voltages with a scope and used a thermal camera to look for possible problems.
      The voltage at the ADC input was 3.12V for 50.6V at the batteries. The 5V, 12V and -8V looked good, though the last had (-8.77V) a bit more than -8...
      The ADC is a TLC0838C. The quad Op-Amp (LF347) near the ADC is heating up a bit.
      I'm going to buy the Electrolytic Caps, the ADC and the Op-amp to replace them.
      I'll keep you posted.
      Thanks.
ID:	3620363 Click image for larger version
ID:	3620364 Click image for larger version
ID:	3620365 Click image for larger version
ID:	3620366 Click image for larger version
ID:	3620367 Click image for larger version
ID:	3620368 Click image for larger version
      I Click image for larger version
      • camisao
        • Jan 2024
        • 11
        • Portugal
        I got the UPS working today.
        I replaced the Caps, Op-Amp and ADC.
        At first it was reading the Bat voltage well again, but the line voltage was 100V less than it should (220)...
        When I first had the problem I searched all over the web and someone at the EEVblog forum mentioned that APC UPSes sometimes have resistor problems.
        I think the issue was in fact a soldering problem (solder joints). I resoldered the sensing resitors arround the ADC and assembled it all again.
        It worked.
        Lets see for how long .
        Thanks.
          LENOVO 3000 J110 3000 J E6300 Specification for Upgrade or Repair
          This specification for the LENOVO 3000 J110 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 3000 J110 boardview and 3000 J110 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO 3000 J110...
          09-12-2024, 03:36 PM
        • gjgib
          Help reading schematic voltages input/output
          by gjgib
          Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
          I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
          I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
          I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
          05-06-2024, 08:11 PM
          ACER Predator Orion 3000 600 I9200 Predator Orion 3000 i5-8400 Specification for Upgrade or Repair
          This specification for the ACER Predator Orion 3000 600 I9200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Predator Orion 3000 600 I9200 boardview and Predator Orion 3000 600 I9200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
          09-12-2024, 03:28 PM
          ACER Predator Orion 3000 PO3-620 Predator Orion 3000 i7-10700 Specification for Upgrade or Repair
          This specification for the ACER Predator Orion 3000 PO3-620 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Predator Orion 3000 PO3-620 boardview and Predator Orion 3000 PO3-620 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
          ACER Predator Orion 3000 PO3-600 Predator Orion 3000 i5-8400 Specification for Upgrade or Repair
          This specification for the ACER Predator Orion 3000 PO3-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Predator Orion 3000 PO3-600 boardview and Predator Orion 3000 PO3-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
