Faulty power supply stopped card reader from working before failure
  • japlytic
    • Oct 2005
    • 2086
    On a client's Dell, I have noticed a problem with the card reader and a couple of months later, it would not start.
    The motherboard Power light illuminates, so I decided to take a voltage reading of the +5VSB rail, which was way down at +3.3V and upon opening the Hipro power supply, I found most of the low voltage electrolytics have bulged (Teapo and LTEC).
    Replacing the power supply fixed this problem, and surprisingly, the card reader started to work again as well.
    Perhaps the card reader was a bit too sensitive to power supply noise (or the rail dropping over time)?
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Faulty power supply stopped card reader from working before failure
    Definitely, I've seen first hand bad capacitors causing computers to run slow, but not crash. Then sometimes it happens the other way around. (not speeding up the computer, just crashing..lol)
    Muh-soggy-knee
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      DVR camera recorder switching power supply capacitor failure really
      These cheap non brand capacitors at it again
      Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
      Well at least I have the cameras back on line I to try the...
      01-22-2022, 06:28 PM
      Mitsubishi CNC switching power supply board dead / relay board bad diode failure
      I was working on this CNC machine today found no keyboard functioning no control relay powering on
      The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
      Found shorted diodes on main controller relays there are 3 of them that...
      01-07-2023, 05:43 PM
    • shovenose
      Ubiquiti Unifi PoE Switch US-8-150W Power Supply Failure
      by shovenose
      Got this one for free because, well, it no worky.
      A little research and there are tons of complaints all over forums/the internet about premature failure of these switches. The observation everyone makes about these is "they run hot" and failure occurring as soon as 13 months, right out of warranty, of course.
      Upon removal of the cover I found a G0398-15011480A power supply that, when plugged in, was making a constant ticking noise. Multimeter confirmed the PSU was the issue. Output was cycling between 0 and about 20V. With output disconnected it sat around...
      08-11-2021, 01:26 PM
    • leonada2008
      ASUS TUF3 video memory power supply failure
      by leonada2008
      ASUS TUF3 3 fan version, under high load, image loss, black screen, flash back, large area of video memory reports unknow error, suspected to be video memory power supply failure, now request a boardview, thank you
      04-23-2025, 01:59 AM
