Hello everyone.
Weekend is coming so I took in my hands one more psu T&P-MEIJI model: Meiji-350 ATX, but this time some components was burned, because fan was stuck. Temperature was increased and two inductors coils was burned.
First I have replaced the burned parts and also checked all capacitors with my esr meter, plus ic's, power FET's, diodes, two c945, A1015 transistors, tl431 regulator and tried to power on with light bulp in serial. No shorts at all but saw a common failure. Got +5vsb output only in psu tester.
I have already made some voltages measurements:
IC: S494P (PS_ON -----PS_OFF)
1: 5.0 m v --- 6.2 mv
2: 4.853 v --- 4.854 v
3: 56.7 mv --- 56.4 mv
4: 3.402 v --- 3.720v
5: 1.656 v --- 1.653 v
6: 3.767 v --- 3.753 v
7: 1.3 mv --- 1.3 mv
8: 2.223 v --- 2.238 v
9: 1.2 mv --- 1.3 mv
10: 1.2 mv --- 1.3 mv
11: 2.222 v --- 2.235 v
12: 11.99 v --- 12.0 v
13: 5.088 v --- 5.090 v
14: 5.088 v --- 5.090 v
15: 5.088 v --- 5.090 v
16: 1.1 mv --- 1.2 mv
IC: S339P (PS_ON -----PS_OFF)
1: 3.975 v --- 35.4 mv
2: 4.283 v --- 150.6 mv
3: 5.087 v --- 5.089 v
4: 1.363 v --- 1.367v
5: 3.735 v --- 1.24 mv
6: 1.9 mv --- 5.072 v
7: 2.692 v --- 2.695 v
8: 1.397 v --- 1.397 v
9: 58.8 mv --- 58.8 mv
10: 2.587 v --- 2.588 v
11: 254.6 mv --- 207.2 mv
12: 1.1 mv --- 1.2 mv
13: 1 mv --- 3.3 mv
14: 4.3 mv --- 8.4 mv
OPTO: (PS_ON -----PS_OFF)
pin 1: 4.040 v --- 4.035 v
pin 2: 2.920 v --- 2.922v
T2 transformer (PS_ON -----PS_OFF)
pin 1: 1.485 v --- 1.497 v
pin 2: 1.485 v --- 1.497 v
pin 3: 1.485 v --- 1.497 v
As you can see on T2 transformer both state voltages are equal. Is this normal or T2 failed?
Green color at PS_ON state does not have voltage, but on switching off state has 5.084 v.
When i shorted pin 4(DTC) with pin 7 (GRD) on S494P ic, the psu worked. Unfortunately is it not turning on in normal mode.
Where is the fan controller component? Since coils burned I want to replace it. Any more suggestions to make it work?
Thanks a lot for you help.
Nicholas
13: 1 mv --- 3.3 mv
Nicholas
What do you mean by that !!!!!!
Is that original Inductor Totally unusable ??? Do you not have any same PCB ??
