Sony J30 PSU repair
  • dadi
    • Jan 2012
    • 5
    Sony J30 PSU repair
    Hi Click image for larger version
ID:	3255905 Click image for larger version
    I am trying to repair an old Sony j30 PSU, which I have no information about or schematics.
    I am not an expert in electronics, but I would appreciate some help.
    I recapped the whole PSU and still no output, though I get about 15-24v on the power transistors on the primary side. The MC33262 controller gets about 15v.
    I get no power on the secondary side.
    By the shottcky diode, where I think I have a short, as I replaced the component that seemed to be a diode (white like those connected to the power transistors with no marking on it, or the board itself). but it didn't change anything.
    Any idea how to proceed?
    Thank you in advance for any help
    Joe
  • kasfamily
    • Aug 2014
    • 765
    • Russia
    What country are you from?
    How many volts are on the C7?
    • Tnmg
      Sony XBR-65X850E power supply board diode replacement
      by Tnmg
      I have a Sony XBR-65X850E that when plugged in buzzes for a few seconds about 5-7 times but the screen never comes on. It looks like one of the four diodes on the main power supply board are bad. I'd like to replace all four at the same time. The diodes that are bad are the D750, D751, D752 and D753. The S750 looks discolored and fails the diode test on the board. It hasn't been removed from the board yet for testing.
      Are all four of these the same diode? I saw a video that called the discolored one a Schottky 5150 diode. How can I make sure to get the right diodes for these?...
      07-01-2022, 04:54 PM
    • karatzdi
      Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
      by karatzdi
      I know some might say... just buy another one. Sell it as parts..!
      So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
      Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
      Spent some time downloading the Service...
      06-11-2024, 08:38 AM
    • Watson306
      6 Red Blinking lights (left side darker) on Sony KD-49XE8396
      by Watson306
      I've got a Sony KD-49XE8396 TV that will switch on show the Sony logo then the Android logo and then switches off, and then blinks red 6 times.
      I've read that this is the backlight, and during it showing the initial logos I can see that the left side is definitely darker.
      I've also read that you can bypass the error to get it working but I'd prefer to fix it if at all possible. Any help would be appreciated.
      Many Thanks in advance.
      11-01-2022, 05:33 AM
    • Carlos#2003%
      Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
      by Carlos#2003%
      Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
      02-15-2024, 07:52 PM
    • ptcriserx3
      Sony trinitron crt bowed and side color issues
      by ptcriserx3
      Hi
      Ive got a vintage 2001 sony trinitron flat tube tv
      The image is slightly bowed and the left and right sides about 1-2in has fluctuating discoloration that comes and goes if i move or hit tv on sides
      See many images attached...
      Just windering if this is not fixable or something i can correct without getting too invloved
      Im trying to sell the tv
      06-17-2023, 07:27 PM
