Possible to boost 12v amp ?
  • Gabriel
    • Jan 2010
    • 620
    • Norway
    Would it be possible to increase 12v from 560mA to 1.5A without replacing transformer ?
    Got this at the dump and thought I modify it with a molex plug to power a external harddrive but 12V amps is low rather low.
  • mariushm
    • May 2011
    • 3799
    Re: Possible to boost 12v amp ?
    Probably not... won't raise it significantly without messing the 5v output.
    But what you could do would be to get a boost dc-dc converter to boost 5v to 12v and place it inside the power supply... something like this would do the job just fine.
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      Interesting design. Looks like the 5V rail uses a schottky diode and is the one that the PSU regulates against while the 12V rail is left hanging without feedback (hence why that LM317 linear regulator is possibly there). Or the actual output of the 12V rail is higher than 12V and that's why they used the LM317.
      Either way... I think it might be possible. The limitation of the PSU is 26W, so if you are to make this PSU purely a 12V adapter, it would be able to do 2A at 12V.
      But first we will need a better picture of the board's solder side (preferably looking straight down on it). There's a 358 op-amp and a second optocoupler. Need to understand what those do before messing with anything, because this doesn't seem like the simple flyback design with just a single optocoupler.
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        Note the capacitance of the output caps and what caps are on the 12V output and 5V?
        • Gabriel
          • Jan 2010
          • 620
          • Norway
          Ahh will have a look at the dc-dc converter if nothing else works out, I might be able to squeeze it in if I remove the RX30,lm317 and its heatsink.
          Took a few new pictures and marked in caps, this is the first psu I ever see with a Rybycon Rx30 130C.
          I need both the 12v and the 5v to power a internal harddrive.
          • PeteS in CA
            • Aug 2005
            • 3581
            • USA, Unsure of Planet
            The key factors are the adapter power rating, the +12V transformer winding, the +12V rectifiers, and the LM317. If you minimize the load on the +5V (so more of the rated power can go to the +12V, you may be able to evade that issue. The +12V rectifiers should probably be rated for 6A-10A (the higher the rating, the lower the forward drop at actual current, which reduces wasted power). While an LM317 rated for 1.5A is probably available, I'd suggest getting a 1.5A rated LT1086. The LT1086 is pin compatible and has the same internal reference voltage, the difference being that it is a low drop-out voltage part. That means the regulator can regulate with a lower input voltage than the LM317; that may be necessary with a light +5V load. The one thing you cannot do much about is the +12V transformer winding. Delta Products is a good company, so they may have been a bit conservative in choosing the current capability of the +12V winding, which would be a good thing for your purposes. You may be able to mitigate the higher temperature some by having a fan blowing on the adapter.
            PeteS in CA
              HP ProBook x360 440 G1 + Samsonite Base Boost Hybrid (2-in-1) Specification for Upgrade or Repair
              This specification for the HP ProBook x360 440 G1 + Samsonite Base Boost Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 440 G1 + Samsonite Base Boost boardview and 440 G1 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
              09-06-2024, 09:00 AM
              HP EliteBook 830 G5 + Samsonite Base Boost Notebook 800 Specification for Upgrade or Repair
              This specification for the HP EliteBook 830 G5 + Samsonite Base Boost Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G5 + Samsonite Base Boost boardview and 830 G5 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
              HP ProBook 650 G4 + Samsonite Base Boost Notebook 600 Specification for Upgrade or Repair
              This specification for the HP ProBook 650 G4 + Samsonite Base Boost Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 650 G4 + Samsonite Base Boost boardview and 650 G4 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
              HP EliteBook x360 1030 G3 + Samsonite Base Boost Hybrid (2-in-1) Specification for Upgrade or Repair
              This specification for the HP EliteBook x360 1030 G3 + Samsonite Base Boost Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G3 + Samsonite Base Boost boardview and 1030 G3 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
