Assus Ati 6450 video card power?
  • ivtec
    • Dec 2008
    • 1967
    Hi guy wish you had good New Year entries" now i ordered an Assus Ati 6450 video card, now i've noticed it requires 500w power sup,i red the reviews and most of them say it works great with power sups 280w Intel cpu i5 P core 2400 with integrated Hd 2000 card,i'm not using it for gaming,just video streaming.
    I've got the specs from Lenovo web site for my PC and it also states i can run an ati hd5450 which is not far from the Hd 6450 on power requirements.
    Will i have problems with this card or problems on the mother board from too much heat?
    http://support.lenovo.com/en_EG/down...D=PD015061#pow
    http://www.amazon.com/Asus-Radeon-Si.../ref=pd_cp_e_0
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Assus Ati 6450 video card power?
    The HD6450 is a low-end card which does not require a PCI-E power connector, so it shouldn't draw much power. Googling reveals it only uses 15 watts at maximum load. Your power supply won't even tell the difference.
    http://www.techpowerup.com/reviews/S...assive/25.html
    A working TV? How boring!
    • ivtec
      • Dec 2008
      • 1967
      Thanks Bro; i checked also this Benchmark between HD2000 i have and ATI 6450.I'm only gonna use it for Video Streaming and Web, also i've chosen this one cause is cheap and has HDMI
      http://www.game-debate.com/gpu/index...-graphics-2000
      linuxubuntu ivtec is online now Report This Post
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
        GeForce RTX2080 Super Aero video gaming card issues help need
        This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
        Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
        05-07-2023, 08:12 AM
      • ChaosLegionnaire
        cracked tantalum cap on a video card. safe to apply power without fireworks?
        by ChaosLegionnaire
        please refer to the attached pics. is it safe to apply power with that tantalum cap like that without causing fireworks? i dont wanna burn a hole through the pcb as the gpu chip is on the other side.
        happened to me once before with a shorted mlcc. shorted mlcc on a vrm power phase burned a hole through the pcb power section but thankfully that was nowhere near the gpu chip. but the video card still ended up in the landfill anyway tho as the burn-through was not fixable.
        so do let me know what u think of the chipped tantalum there. thanks....
        09-08-2024, 07:05 PM
        03-31-2024, 02:12 PM
      • gcrezz
        GV-N2060OC-6GD REV 2.0 GIGABYTE video card troubleshooting assistance needed.
        by gcrezz
        The issue with this video card is the HDMI port. Specifically on pin 19 (Diode checks on all other pins are normal). When i do a diode check on it from the pin on the board itself, I have nothing. There is also no short on the pin. Resistance reads about 200k. Normally on any HDMI pin 19 I would expect some voltage drop anywhere from .5v to 1.2v but here, I have nothing. The card is operational and can be used via the displayPort ports, but not through the HDMI. Attached you will find the pdf schematics for the card on page 22. I have verified that all of the resistors on this line before the...
        07-25-2024, 09:49 AM
