Shure AC Adapter PS60E
This topic has been answered.
  • ant3202
    • Jun 2006
    • 275
    • Singapore
    Hi All
    I had a Shure AC Adapter PS60E that was dead suddenly after a power outage.
    Output 15V - 4A
    60W Max
    Capacitors were
    Samxon RT on Primary Side
    Samxon GF on Secondary Side
    Did some troubleshooting and observed that
    SS210 is Shorted at D6
    Seeking help to Identify IC2 as comparing with a working adapter, having shorted reading.
    Thanks ))))
  • Answer selected by ant3202 at 04-01-2024, 06:46 PM.
    redwire
    • Dec 2010
    • 3910
    There is no PFC. The blown diode D6 is on the secondary side.
    It looks like it has synchronous rectification. IC2 I9HKK or |9HKK is MP6901DJ
    D6 is supposed to be covered by the TO-220 check the mosfet is not open-circuit or IC2 not working.
    • temyth
      • Jan 2024
      • 45
      • Brazil
      I'm not sure what is the reference of IC 2 but if your PSU experienced a power outage i would certainly check the PFC Mosfets, they commonly go damaged after power outages in most cases.
      • ant3202
        • Jun 2006
        • 275
        • Singapore
        thanks for replying
        Had tested with a multi tester and the mosfets were fine.
        • redwire
          • Dec 2010
          • 3910
          • temyth
            • Jan 2024
            • 45
            • Brazil
            you're right! thans for pointing my error, these psu's work without active PFC
            • ant3202
              • Jun 2006
              • 275
              • Singapore
              much appreciated!!!!
              • ant3202
                • Jun 2006
                • 275
                • Singapore
                Update:
                Many thanks to redwire !!!!!
                It works after replacing the components!!!!!!
                The MP6901DJ takes a long time to reach. (Aliexpress)
