HEC-250LR-T ATX Computer psu
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Re: HEC-250LR-T ATX Computer psu
    Originally posted by Agent24
    Sorry, where I said "gate to source" should have been "drain to source"
    Or in other words, the two right-most legs on the package when viewed from the front.
    ok merry xmas
    is interesting that R011 is open on your supply as well.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
    • joshnz
      • Feb 2011
      • 969
      • New Zealand
      agent the missing resistor from your psu is 388k by multimeter
      orange white yellow gold 390k ohm on my psu.
      My pc
      • Agent24
        I see dead caps
        • Oct 2007
        • 5016
        • New Zealand
        Thanks, now I just have to figure out why mine is nothing more than a pair of leads...
        -David VanHorn
        • joshnz
          • Feb 2011
          • 969
          • New Zealand
          Your psu has a different controller I think they might not need it. I wonder why r011 is open must be a short on your 5vsb.
          My pc
          • joshnz
            • Feb 2011
            • 969
            • New Zealand
            Well I got my 5vsb controller today and it is not happy.
            I have a 100watt bulb in series (where the the resister blew)
            And it is ticking as if there is a short there is no short.
            control has 5volts that is near under voltage cutout.
            My pc
            • Agent24
              I see dead caps
              • Oct 2007
              • 5016
              • New Zealand
              #26
              Try with a new resistor, and put the lightbulb on the AC input in series with entire PSU on the active line?
              A repetitive noise in an SMPS is not always a short
              (http://www.repairfaq.org/sam/smpsfaq.htm#smpsstsm)
              -David VanHorn
              • joshnz
                • Feb 2011
                • 969
                • New Zealand
                #27
                as i stated in last part of post it is in under voltage mode.
                may be the case as the filament in the bulb is inductive
                My pc
                • joshnz
                  • Feb 2011
                  • 969
                  • New Zealand
                  #28
                  Still not happy.
                  I removed fuse and attached 100 watt bulb and put in .44 ohm resistor with no change
                  My pc
                  • Escort Eagle
                    • Jul 2012
                    • 110
                    Why are you removing fuse ? Use Series bulb outside of the circuit, put series bulb in your main AC line, Not inside from your circuit board . Now tell us - Is series bulb still glowing after 3 seconds ?
                    • joshnz
                      • Feb 2011
                      • 969
                      • New Zealand
                      #30
                      Because it is much less hassle then chopping up a cord just to intercept the phase. And is electrically the same.
                      Not glowing the controller is going into under voltage protection.
                      Because control is on the under voltage threshold.
                      My pc
                      • Escort Eagle
                        • Jul 2012
                        • 110
                        That means you have no 5VSB at output . This is why Control (C) is remaining on the under voltage . It could be happen due to two reasons - One for secondary side problem and other for Primary side .
                        First - check those parts in the secondary side which are regulating 5VSB . How 5VSB is regulating ? Is it regulating by TL431 or zener ? If so, then check that TL431 or zener and other surroundings resistors and capacitors . And don't forget to check the Opto-coupler also .
                        • joshnz
                          • Feb 2011
                          • 969
                          • New Zealand
                          #32
                          Found the problem aux winding had a break.
                          Running normally now.
                          My pc
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5016
                            • New Zealand
                            #33
                            That seems odd, since the model and revision are exactly the same. Then again, it wouldn't be the first time a manufacturer changed a design without modifying the sticker...
                            -David VanHorn
                              Acer Swift SF114-34-P2H0 + Pack Gold Acer 14'' Notebook 1 Specification for Upgrade or Repair
                              This specification for the Acer Swift SF114-34-P2H0 + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P2H0 + Pack Gold Acer 14'' boardview and SF114-34-P2H0 + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                              09-07-2024, 03:10 AM
                              Acer Swift SF114-34-P25P + Pack Gold Acer 14'' Notebook 1 Specification for Upgrade or Repair
                              This specification for the Acer Swift SF114-34-P25P + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P25P + Pack Gold Acer 14'' boardview and SF114-34-P25P + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                              Acer Swift SF114-34-P25P + Pack Gold Notebook 1 Specification for Upgrade or Repair
                              This specification for the Acer Swift SF114-34-P25P + Pack Gold Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P25P + Pack Gold boardview and SF114-34-P25P + Pack Gold schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                              09-07-2024, 02:20 AM
                              Acer Swift SF114-34-P2H0 + Pack Gold Notebook 1 Specification for Upgrade or Repair
                              This specification for the Acer Swift SF114-34-P2H0 + Pack Gold Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P2H0 + Pack Gold boardview and SF114-34-P2H0 + Pack Gold schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                              ASUS 14.0 FHD 1920x1080 Pentium Gold 7505 4GB 128GB with M365 1 Year Notebook Specification for Upgrade or Repair
                              This specification for the ASUS 14.0 FHD 1920x1080 Pentium Gold 7505 4GB 128GB with M365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14.0 FHD 1920x1080 Pentium Gold 7505 4GB 128GB with M365 1 Year boardview and 14.0 FHD 1920x1080 Pentium Gold 7505 4GB 128GB with M365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
                              09-07-2024, 01:30 AM
