AcBel API0PO13 does not power on. Fan spins a bit then stops.
  • sententia
    replied
    Re: AcBel API0PO13 does not power on. Fan spins a bit then stops.
    Originally posted by Toasty
    Yeah, missed that on the first post.
    Perhaps if it was noted as Wincor POS I would have caught it more readily. Age.
    The ML4800CP is the PFC controller and that daughterboard is it's supporting circuitry.
    I'd replace (from experience) the small cap on the main board right in front of it and see what happens.
    T
    After removing and testing many many parts from the PSU i came across to the first definite suspect of the problem. The little capacitor right next to ML4800CP on the daughterboard has about 70 - 80 ohms ESR. Toasty suggested to test the one on the front on the main pcb. I didn't check the small one next to the ic because i didn't have the esr tester nor a replacement at that time. The capacitor is a 3.3uf 50V.
    I can't really test the psu as i have destroyed a couple of parts on the pcb however if someone meets the same problem i strongly suggest to check that little capacitor as PSU didn't have many working hours and ALL other parts, especially rail capacitors tested like new.
    I tested the cap because of a problem i came across on a different psu which was solved by changing a couple of capacitors in the PWM circuit.
    P.S. Can i use any of the sub circuits to "be" anything by itself ? especially the small board with the transformer on it? The transistor is a power fet IRFBC20 and the small ic on the bottom side is a TL431. Thank you.
    Best regards.
  • Behemot
    replied
    Thermistor, likely for fan regulation.
    Generally, no. They have much lower inductance, will act like conductor (short) for 50 Hz.
  • sententia
    replied
    I started disassembling the psu as i am running out of hope ....
    So here are so more pics. Does anyone know what the green capacitor like part is? (TCJ 103)
    Possibly a newbie question but ... do you know if the smps transformers can be used as regular ones on 50hz ac? I have done some research but haven't come to a conclusion....
    Thanks!
  • sententia
    replied
    Just measured again resistances to ground.
    3.4v gives 15ohm (does this sound correct?)
    5v rises and stops at 202ohm
    12v rises up to 5k after some time drops to 0ohms (multi at 20k), on multi 2k it goes up to 1.8k.
    Where the 3.4v rail is connected to the pcb there is a 0.01ohm resistor but i cant understand where the other pins goes. Seems to connect to an inductor and possible some capacitors but i am not sure!
    It seems that the 3.4v rail has different behavior the the others. If that help anyone for some direction....
  • sententia
    replied
    Just tested on the pc ... sensor is ok.
  • sententia
    replied
    I know that it is giving me a hard time.... i also know that my knowledge is very basic about all the parts of the PSU which makes think more difficult. Anyway do know that the psu has sensors on the voltage rails... My mistake was that when i found out i had a identical working psu (so now i do not need the current one... i try to save it for educational purposes and to have a spare one) i didn't take a note from the pin voltages in order to check the one i have now... The only thing i remember is that the pinout cable colors do not follow the atx logic... I found that on the second connection jack the grey wire was -5v (if i remember correctly) etc..
    About the fan now.... Funny or not i also suspected, although a long shot, that it may be a fan problem.. However the fan when connected to power source spins excellent... I have not tested is if there is a problem with the fans sensor (yellow wire).
  • Escort Eagle
    replied
    Sententia, Is it creating heavy load on your brain !!! PSU SMPS is one of the most difficult SMPS which forms all kind of critical problem found other than any SMPS circuits !!
    Let me clear your problem Fan spins a bit then stops That means - Your controller IC is detecting an Absence one of your Output voltage . This is why controller IC is telling PSU to keep shutdown . Now find which Output voltage is remaining Absent to the Controller IC .
    I want to share one of my experience with you - Few years ago I got a PSU from a customer which Fan spins a little bit and then stops !! After searching for several hours in secondary and primary side, I found nothing problem !! You will be surprised to hear that what was the problem there !! Can you think what was the problem there ?? At the end I found that The Fan was Bad itself !! This why Controller IC was shutting down the PSU .
    I will suggest you to check this FAN with other PSU or with a 12V supply .
  • sententia
    replied
    Nothing close? Anything from 47 to 100µf @ 25/35/50v will work for testing.
    T
    I had some 47μf caps so i tried with one and two in parralel but no joy....
    It feels a difficult catch really...
  • Toasty
    replied
    Originally posted by sententia
    ...I removed the capacitor from the main pcb, as i couldn't read it, and it is a 68μf 25v. Unfortunately i don't have a replacement to test it...
    T
  • Behemot
    replied
    I have some feeling that if primary caps go bad, than it's like in this case Being on high voltage, quite often strange things (lightning, explostions) happen…
  • sententia
    replied
    T
    No worries.... i just mentioned it to give some more detailed info about the POS!
    T
    I removed the capacitor from the main pcb, as i couldn't read it, and it is a 68μf 25v. Unfortunately i don't have a replacement to test it.. I really hope my esr meter arrives soon....
  • sententia
    replied
    Originally posted by ben7
    I first have to thank you for the good pictures you provide. I'm tellin ye, they help a lot!
    About the 'bulged' capacitor ... it likely isn't bulged. Those plastic caps on top quite often warp from heat (regular temps, not overheating temps!). press down on it, if the capacitor isn't bulged then it should squash inwards. If it feels like something is under it, then you can cut the plastic disc off to see underneath. The plastic disc is there to help with insulation from other stuff, as the capacitor can could be at a high voltage potential, being on the primary side (mains voltage in this case) of the PSU.
    Thanks about the pictures...! I hoped they would help!
    You are right about the capacitor... it is just the plastic swollen, underneath feels empty ...
  • ben7
    replied
  • Toasty
    replied
    T
  • sententia
    replied
    As this seems to not be a computer PSU, rather an ATM or some such banking device, the voltages and methods it uses to turn on are unclear. In other words, it may need a signal from whatever it powers to turn on some of the other voltages.
    Wincor Nixdorf - WN P/N: 01750043987
    3.4 volt is not typical; 3.3v is.
    24v is not typical except in industrial controls and Apple products.
    -5v is not typical, but the -12v was, back in the ATX time period.
    A shame that you damaged the board. If you can correct the damage, then perhaps we can go through this diagnosis.
    Schematic and/or information as to the device this powered may provide clues to the method of operation.
    Yes, I think it might be a primary side issue. At the least, it could be a PFC issue. Without voltage readings, it is not possible to be sure. With 220vac mains you should have ~312vdc across the cap at Standby and ~385vdc when On.
    The 9v max on the 12v line is kind of a giveaway that the PFC is not working.
    T
    As i mentioned this PSU comes from a wincor POS (point of sales) system. Just for the record it is a BEETLE /M (i attached some pics) that uses pentium /celeron s478 cpus... The 24v rail is used for the recpeipt printer...
    I found another similar psu that is actually working. What i found by coincidence is that the psu turns on with another green wire than the one i used (the one on the plug that has 12v 5v and 3.4v rails)! So i went today and installed in the machine and everything works fine. I tried that on the psu that this thread refers to and it has the same symptoms as before, fan spins a bit than it stops. So i must have been wrong. I suppose no damage to pcb after all...
    I have attached some images from primary side, if that helps, with what i believe to be the pfc. I also noticed on the good psu that the mains capacitor is not bulged at all and is totally flat. I thought that does not matter as ALL the working psus i have opened seem to have bulged mains capacitors without a problem. Anyway i expect a ers capacitance meter to arrive soon so i will be able to test that also.
    By the way i can't find schematic anywhere...
    Thank you very much for the input!
    P.S. I forgot to note outputs and cable colors of the working psu.. clumsy me..
  • Toasty
    replied
    T
  • sententia
    replied
    The mains cap is a 120μf 450v..
    About the 5vsb. There are two purple cables going in to each connector. One does give 5v the other 0v. Both are connected to pcb via a connector located at the corner (last photo of first post)
    I haven't measure voltages before after mains capacitor as i don't feel very confortable working on live pcb yet.
    Do you think there might be a problem on the primary side?
    P.S. I might have damaged the pcb trying to remove switchmode diodes (before buying the correct iron tip), as i short now one of the three green wires which to kick the fan but no go...
    Do you have the 5vsb?
    What is the voltage rating of the mains cap?
    What voltage do you have across the mains cap at:
    1) Standby?
    2) On?
    T
  • Toasty
    replied
    1) Standby?
    2) On?
    T
  • sententia
    replied
    Thanks for the input...
    If any of the power fets was shorted, the fuse should blow if i am correct...
    Do you think that i should desolder them and test them?
    Correct! They are power transistors, most likely MOSFETs.
    Could you take them out and test them? See if they have any shorts.
    Does this PSU have a standby voltage also?
    Did you get the PSU broken, or did you just find it? Some don't run without some load on the output, this *could* be the problem.
    About the other PSU ... I don't know, if you do start another thread, make sure it is titled "Another AcBel API0PO13 - different problem" or something like that, so mods won't mistaken that as a double thread. (Some people post multiple threads for the same problem - that isn't allowed on here as far as I know)
    Cheers,
    -Ben
  • sententia
    replied
    Both PSU i have come from same machine. I have it and i tried to test them on the original equipment. So it sould not be a load problem.
    Yes they do have standby cable. The first one (that this thread refers to) has normal +5v on the green cable and "tries" to start when it is shorted to ground. The other one is just dead.... 0v
  • NConstantinou
    HP 8000 series power supply Fan spins and stops
    by NConstantinou
    Hi all
    i have an HP power supply PS-4321 connected in series with bulb.
    Series lamp is blinking when i short green wire and ground.
    Voltage on mail capacitor is fluctuating.
    i changed all capacitor but still the same.
    i checked for short NO SHORT.
    i looks like power supply is restarting that is why series lamp is flashing.
    without power i do get correct voltage on main capacitor NO FLUCTUATION but i am missing 6v on a smd capacitor that is connected directly on ic 6802.
    i also changed ic 6802.
    there are 3 optocoupler...
    10-13-2022, 09:01 AM
  • Cornito
    Denon AVR-2700H audio stops while receiver still works
    by Cornito
    Hello team,
    I've got a new issue with a Denon Avr-2700H.
    After several minutes working, receiver stops playing sound with a poc eared in the speakers.
    Receiver still work and display video with error message on display.
    Seems to me that is the main output relay.
    I'm looking for the service manual that I can't find for the moment.
    Does somebody have it?
    Regards...
    08-03-2025, 06:10 AM
  • carlucci
    Lenovo thinkpad T15; Symptoms: pressing power on, fan spins up but no POST, never getting to BIOS.
    by carlucci
    Lenovo thinkpad T15 Gen2
    Board: NM-D352 rev.: 2.0
    type 20W5 S/N PF-3TGB08
    I already replace bios without sucess. Can someone give me a tip ?
    Regards,
    06-06-2025, 05:33 AM
  • helpmepleasethanks
    Thinkpad T440P bios repair after WIFI whitelist mod
    by helpmepleasethanks
    As per the the rules, here are the specifications of my laptop :
    • Make and model number : Thinkpad T440P
    • Serial number (S/N) : PB-03A7V7
    • Model type - Model (MTM) : 20AW-S2N800
    • Bios version : 2.50 (not 100% sure, that's what I remember)
    Here is the problem, and the events leading to it :
    1. Upgrade screen, keyboard, trackpad, RAM and CPU
    2. Reboot and use the laptop for a bit : everything is working fine
    3. Shutdown (no power) and upgrade WIFI with unsupported chip (AX210)
    4. Boot up the device : bios warning, as expected
    5. Shutdown the device again (no power)
    6. Connect the 8-pin clip of a CH341a
    01-09-2025, 12:09 PM
  • 1goodcap
    HP Prodesk 400 G2 MT - Fan spins but no display
    by 1goodcap
    I'm having a bit of trouble with my HP Prodesk 400 G2 MT. (At first it was giving 4 beeps with blinking red light) at start up. After replacing a shorted 4C08N MOSFET, it now boots directly when I plug in the AC cable without pressing the power button. The fan spins, but there's no display.
    I've tried flashing the BIOS using A ME CLEAN firmware, but that didn't solve the issue.
    Has anyone else encountered this problem? Any suggestions or troubleshooting steps would be greatly appreciated.
    Thanks in advance!​
    09-28-2024, 04:40 PM
