I have this AcBel PSU which is not a usual ATX supply. It does have a 24v rail and two connectors which go to the motherboard (the supply comes from a wincor pos).
As i mentioned the fan when i try to power it on spins for a bit then stops. I went forward and replaced all the capacitor allthough they did not have any visible signs of wear but that didn't help. I haven't replaced the last two 2200uf 6.3v near the output cables as i doubt that it is the problem. Unfortunatly a cheap ESR meter i bought still hasn't arrived so i can't really test the capacitors i removed.
I have no clue at all where to start looking to find the problem.
Allthough the connector have 3 green cables, only 1 seems to try to power it on. I checked the 12v rail with a multimeter and when the PSU tries to start the volt goes up to 8 - 9 v.
Any help is greatly appreciated.
P.S. this is THE HARDEST pcb to desolder i ever encountered!
