Dodgy Display on a Skytronics PSU
  • ceedy
    • Nov 2008
    • 76
    I bought a "as NEW" Skytronics Variable PSU model 650.679
    like this..
    And not actually used it myself for a month or so since purchase and now it seems to have problem with the Volts LED display.
    The whole thing works as it should, fully range of volt and Current limit at the output .. but the LED Volts display is all over the place, almost completely random digits appear , no relation to the actual output, which I can check with my Fluke meter.
    couple of videos in here..
    http://s277.photobucket.com/user/ceedy44/library/PSU
    The Display PCB has just 5 wires into it .. and the correct variable output voltage is found at 2 points on the this cable .
    The display is fairly simple 1 block of 3 x 8 segments for the current and the same for the volts. both driven by an ICL7107CPL and the only other semi is a TL431A .
    PICs of the board
    Volts on the right side..
    and
    Can't even find who actually makes this PSU .. so little chance of any spares?.
    Any clues anyone ??
    The only slight plus it was cheap
    Chris
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Re: Dodgy Display on a Skytronics PSU
    You will have to check if vref hi and lo are stable and input hi and lo are stable
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
    • mariushm
      • May 2011
      • 3799
      ICL7107 are multimeter chips with led driver option ... they measure voltage and activate the appropriate led segments by themselves.
      I would bet on cold solder joins on the led segments or some issues with the integration capacitors (the brown ones)
      Retouch all the solder on the segments and IC and check the capacitors with a multimeter.
        • Jul 2011
        • 6046
        I would look very close at all of the soldier joints for the volt meter any joint that has allot of flux on it reheat them or looks even a little bit dull if you have doughs redo all of them
        I hope this helps
        • ceedy
          • Nov 2008
          • 76
          I've just reflowed the majority of the joints on the Volts side of the board , there a couple that looked OK until I got my digi microscope on them.
          And it all seems to be running ok .. gave it a quick trim to the Fluke ( one of them is probably right )
          Very many thanks to all you guys for the clues ..
          take care all
          See you with my next problem
          Chris
          • joshnz
            • Feb 2011
            • 969
            • New Zealand
            good that it is working now
            My pc
              • Jul 2011
              • 6046
              I see that you got it work again
