I bought a "as NEW" Skytronics Variable PSU model 650.679
like this..
And not actually used it myself for a month or so since purchase and now it seems to have problem with the Volts LED display.
The whole thing works as it should, fully range of volt and Current limit at the output .. but the LED Volts display is all over the place, almost completely random digits appear , no relation to the actual output, which I can check with my Fluke meter.
couple of videos in here..
http://s277.photobucket.com/user/ceedy44/library/PSU
The Display PCB has just 5 wires into it .. and the correct variable output voltage is found at 2 points on the this cable .
The display is fairly simple 1 block of 3 x 8 segments for the current and the same for the volts. both driven by an ICL7107CPL and the only other semi is a TL431A .
PICs of the board
Volts on the right side..
and
Can't even find who actually makes this PSU .. so little chance of any spares?.
Any clues anyone ??
The only slight plus it was cheap
Chris
like this..
PICs of the board
and
Any clues anyone ??
Chris
