Apple MDD PSU - ACBEL API1PC36
  • Purge
    • Dec 2012
    • 4
    I have an Apple MDD Power Supply made by ACBEL, model number API1PC36 that is failing to turn on.
    I have not replaced the capacitors yet, because I was hoping to learn a little more about the unit without just throwing parts at it.
    I have read through this thread a few times, and made it to the point where he was checking Pin 2 of Opto M8, where I ran into an issue.
    When checking pin 1 and pin 2 prior to jumpering on, I see 5.4vDC or so on both pins, when I jumper on, the fans twitch and both pin 1 and pin 2 go low. At first I thought this was a good sign, until I realized that not only do they go low, but all voltages are lost.
    Checking the voltages from the motherboard connector I find the 25v gone, as well as the 5 volts gone.
    Before I just go replacing all the caps, does anyone have a good starting point and or procedure for testing a few things? I don't mind replacing the caps, I just don't want to do it only to find they were not the original problem.
    Thanks!
  • Purge
    • Dec 2012
    • 4
    Re: Apple MDD PSU - ACBEL API1PC36
    I thought I should add that I have purchased replacement caps to recap all of the secondaries, as well as the startup caps just as a refresh since most of the caps were Teapo.
    I just want to ensure that the above symptoms aren't signs of a different failure.
    • Toasty
      • Jul 2007
      • 4171
      The thread you read is the longest of them. There are several other threads to help:
      https://www.badcaps.net/forum/showthread.php?t=13985
      https://www.badcaps.net/forum/showthread.php?t=19206
      https://www.badcaps.net/forum/showthread.php?t=14708
      The 5v and 25v are standby power, IIRC (been a while since I was in one of these).
      The cap that is at the corner of the center heatsink (near the opto's) is the usual culprit, C43.
      T
      veritas odium parit
      • Purge
        • Dec 2012
        • 4
        Thanks Toasty,
        At first I didn't want to replace all the caps, I really wanted to determine the fault and replace only that component.
        I changed my mind obviously, for two reasons:
        1) Improper test equipment (No ESR Meter)
        2) If I want this thing to last awhile, $10 in parts for a refresh is not bad at all.
        The caps should be here tomorrow. Coincidentally, I have tomorrow off of work.
        I'll try to get them all replaced tomorrow and give it a good test run.
        Will update here with progress, as well as a list of what I used as replacements for each component.
        • Purge
          • Dec 2012
          • 4
          Replacement caps worked like a champ.
          I'm using this as a bench-top power supply.
          Installed a panel-mount fuse holder to replace the soldered in fuse.
          Built a small voltage regulator circuit using an LM317T fed off of the 28v rail.
          All that I have to do currently is drill and mount my potentiometer for the variable voltage circuit, and drill/mount and connect the binding posts for 5v, 12v, variable, and ground.
          The only complaint I have so far is that I'm using a 10K pot which makes fine voltage adjustment near impossible. A 2 or 5k pot would be better (even if I dont feel like doing it at this point.)
          Thanks again for the help!
          • Toasty
            • Jul 2007
            • 4171
            Try these. Super fine adjustment.
            http://www.circuitspecialists.com/pr...potentiometers
            T
            veritas odium parit
            • a_p3rson
              Apple Watch Charging Controller Schematics / Boardview - 820-02601
              by a_p3rson
              Hi there,
              I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
              You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
              This daughterboard uses an interesting...
              04-21-2025, 11:41 PM
              HP ProDesk 600 G5 + Apple AirPods ProDesk 600 i7-9700 Specification for Upgrade or Repair
              This specification for the HP ProDesk 600 G5 + Apple AirPods can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Apple AirPods boardview and ProDesk 600 G5 + Apple AirPods schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
              09-12-2024, 02:30 PM
              HP ProBook 650 G5 + Apple AirPods Pro Notebook 600 Specification for Upgrade or Repair
              This specification for the HP ProBook 650 G5 + Apple AirPods Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 650 G5 + Apple AirPods Pro boardview and 650 G5 + Apple AirPods Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
              09-06-2024, 07:50 PM
              HP EliteBook 850 G6 + Apple AirPods Pro Notebook 800 Specification for Upgrade or Repair
              This specification for the HP EliteBook 850 G6 + Apple AirPods Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G6 + Apple AirPods Pro boardview and 850 G6 + Apple AirPods Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
              HP EliteBook x360 1030 G4 + Apple AirPods Pro Hybrid (2-in-1) Specification for Upgrade or Repair
              This specification for the HP EliteBook x360 1030 G4 + Apple AirPods Pro Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G4 + Apple AirPods Pro boardview and 1030 G4 + Apple AirPods Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
