my imac intel EMC no#2133 model no#A1224 did not power so i suspec the power supply not working and i check the component i see 1 cap has broke the cap has 420v 150uf but i cant find the same cap i get 1 450v 100uf and i try to replace but when i try to fire up still not power on plz help me !!!thanks a lot
i mac intel power supply problem!!!
Re: i mac intel power supply problem!!!
You replaced 150uF with 100uF? The power supply would be unlikely to work properly. Being Japan, the capacitor capital of the world, I'm very surprised you can't find a replacement capacitor.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
I found these
www.digikey.com
http://www.digikey.tw/tw/en/digihome.html
EET-UQ2W151CA
ECO-S2WP151BA
ECO-S2WP151DA
450QXW150MEFC18X40
381LR151M450J042
LGU2W151MELALast edited by sam_sam_sam; 11-04-2012, 07:32 PM.Comment
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
Assuming...7 Photos -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
This specification for the HP Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC boardview and Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will...09-12-2024, 03:36 PM
- Loading...
