Antec Smart Power SL-400 5vsb mod using VIPer 22A
  • everell
    • Jan 2009
    • 1514
    Re: Antec Smart Power SL-400 5vsb mod using VIPer 22A
    I recently acquired a Smart Power 430. Don't like that 2 transistor 5vsb circuit, so made a mod using the NCP1216 pwm chip. The original 5vsb circuit is the same as the Antec SL series, but the component numbers on the pc board are not the same. So I took a copy of my original SL400 5vsb circuit drawing, and changed the component numbers to match the TruePower 430. Next I made of drawing of the modified circuit. Wired it up, turned it on, and BANG! See picture of damage to switching FET transistor! Some troubleshooting revealed that I had overlooked the 1 ohm resistor between FET source and ground. This power supply was dead when I first got it, and apparently the problem was a blown 5vsb circuit. So the source to ground resistor was still open.
    Replaced the FET, NCP 1216, open resistor, and powered up again. This time the 5vsb was working fine.
    Voltage readings on this power supply:
    12.31v
    5.07v
    3.342v
    5.13v 5vsb
    Didn't want to let this one get away because it has two nice Rubycon capacitors on the primary side. Most of the other capacitors are the "F" brand and still need to be changed. The 5vsb mod was a success.
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
    • LDSisHere
      • May 2012
      • 727
      • U.S.A.
      #42
      I am glad to see you have had a chance to do some more experimenting with the NCP1216. Although I have not yet had a chance, I intend to modify one or both SP's that started a thread on a while back ago.
      It really sucks when you go to power something up after a repair/mod and it goes bang. It is bad enough when it just does not work, but when it causes you too need more parts, time and effort it can be frustrating. I have a bad habit of overlooking those low ohm resistors myself, especially if they are covered in heat shrink tubing. It is great that you were able to get it all working again, probably better than new in this case.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        And .... that is why I always get at least 2 of a certain part, one extra in case of a mess up ... those small smd chips can be fragile.
        Muh-soggy-knee
          HP EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch EliteDesk 800 i5-9500T Specification for Upgrade or Repair
          This specification for the HP EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch boardview and EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
          09-12-2024, 02:30 PM
          HP ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch ProDesk 600 i7-9700 Specification for Upgrade or Repair
          This specification for the HP ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch boardview and ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
          HP ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch ProDesk 600 i5-9500 Specification for Upgrade or Repair
        • CWEastwood
          Antec Smart Power SL300S capacitor replacement.
          by CWEastwood
          I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
          The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
          I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
          Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
          03-25-2023, 12:18 PM
          HP ProBook 430 G6 + Fitbit Versa Smart Fitness Watch Notebook 400 Specification for Upgrade or Repair
          This specification for the HP ProBook 430 G6 + Fitbit Versa Smart Fitness Watch Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Fitbit Versa Smart Fitness Watch boardview and 430 G6 + Fitbit Versa Smart Fitness Watch schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
          09-06-2024, 12:00 PM
