Philips 55PFL5505D/F7 white blinking light
  • computerguy2
    • Oct 2012
    Hi everyone;
    I have a PHILIPS 55PFL5505D/F7 where the white LED blinks 21 times then repeats with no audio or video....no power.
    The powersuppy model no. is UPBPSPDEL003 REV000.
    I have replaced all the caps except two 150uf 400V on the primary side of the power supply, which shouldn't be an issue and I get the same problem, no power.
    If the TV is unplugged for awhile then pluged back in, it will sometimes turn on.
    Any help or suggestions would be appreciated.
  • exclusivebiz
    • Mar 2013
    Re: Philips 55PFL5505D/F7 white blinking light
    Hi, did you ever get this resolved? I have a similar issue but for a 46" I replaced the inverter board but still no go.
    • Khron
      • Sep 2006
      • 1350
      • Finland
      Maybe try to ask a moderator / administrator to move this to the TV section?
      Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
      • NConstantinou
        DELL INSPIRON P66F BLINKING AMBER 3 TIMES AND WHITE LIGHT 5 TIMES
        by NConstantinou
        I REMOVED INTERNAL BATTERIES AND I SUBSTITUTE RAM BUT STILL THE SAME.
        WHEN I PLUGIN CHAGER I DO HAVE 3.3,5 AND 1.8 V. AND ON PL700 I GET 0.27V.
        BIIOS PINS 7,8 I HAVE 3.3V
        IS THE PROBLEM ON MOTHERBOARD OR BIOS.
        08-21-2025, 03:23 AM
      • dani521
        LG SJ2 all light blinking white
        by dani521
        Hello i`am having an LG SJ2 when power is applied the after 1 second of red light ,all the other lights starting to blinks whyte
        do anyone have a dump of this Sound BAR
        CPU is mlc3730SD
        flash is W25Q32
        already on other forums and others has the same problem but no anyone have a working dump ,The problem happens after Bad software update thru LG app , USB update is not working
        will really appreciate if someone has a working dump from SJ2 or SH2 because they are almost same and the code can be fixed with hex editor
        02-07-2024, 12:40 AM
      • YasaCh
        Sony kdl 40p5500 red light keeps blinking 3 times
        by YasaCh
        Hello...
        my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
        i opened the back cover no sign of damage on the powery suply or motherboard
        when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
        another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
        07-07-2025, 11:53 AM
      • What?
        Vizio SV422XVT blinking amber/white power light
        by What?
        Good day, hope all are healthy and cozy. I could use some help with my malfunctioning Vizio with a blinking power light. I have narrowed the problem to the main board but not sure what to do next. I guess it would be good to start with what I have done.
        Problem:
        I have no image, no sound, blinking power light. (left it plugged in overnight and it was still blinking the following morning). I tried the Vizio recommendations (hold power button for 30 seconds, press reset button, check the outlet is live)
        Power Board:
        I am getting 5v only. I have unplugged...
        04-27-2020, 06:21 PM
      • paulyboy
        Acer Spin 5 LC56-14A AMD White Light on Esc and Caps lock Key and Blinking power btn
        by paulyboy
        System doesnt post, I have found that 3v 5v and 19v rails present and accounted for.
        theres 19.5v with a 2amp current drawover usb c charging
        I have tried a new bios and cleaned me region but no change in behaviour.
        I have noticed that the Mosfet PU4403 gets quite hot 60 degrees, but cannot find a short on it or surround components also pu4401 which is the BQ charging chip is also quite hot 60 degrees.
        Have removed BQ and checked pads but no shorts.
        Also on PU4405 PIN 2-4 is suppose to be 19v as per schematic 19V_dcbatout...
        09-12-2023, 05:32 PM
