Bestec ATX100-5 no +5VSB
  • everell
    • Jan 2009
    • 1514
    Re: Bestec ATX100-5 no +5VSB
    Buy a differential probe for your scope. Cost is about $200....but a Bestec psu is worth it!
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
    • everell
      • Jan 2009
      • 1514
      Originally posted by GnatGoSplat
      How can I isolate the ground on an AC-powered earth-grounded oscilloscope so I can see what kind of signal is going into the base pin of the transistor?
      Buy a differential probe for your oscilloscope. They cost about $200.....but a Bestec psu is worth it!
      • GnatGoSplat
        • Jul 2011
        • 50
        Originally posted by b700029
        Isolate the DUT using the isolation transformer, not the scope.
        More information here:
        http://www.eevblog.com/forum/beginne...ge-to-a-scope/
        Thanks, I gave that a try and it does the trick. I happened to have an old isolation transformer that I hadn't touched for years.
        I did put my scope on it to see there is nothing going into the Base pin, V+ on Collector (through transformer primary), and V- on Emitter. No pulses at all. Guess I'll have to draw up a schematic diagram to determine whether those SMD parts are diodes or transistors.
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Yes you should. There is a small capacitor -usually 10uF, sometimes up to 47uF- on the primary side, measure the voltage across that.
          Either something in the feedback has gone bad, or the driver transistor is blown.
          Muh-soggy-knee
          • everell
            • Jan 2009
            • 1514
            Here is a schematic of the 5vsb in a Bestec ATX-250-12E. It should be similar although not exact. Maybe this will help...........
            • b700029
              Banned
              • Sep 2010
              • 640
              #26
              Your schematic appears to be missing the startup resistor - it's several hundred k and usually connected from HV+ to the base of the switching transistor.
              • GnatGoSplat
                • Jul 2011
                • 50
                Looks like it doesn't exactly have a 2-transistor 5VSB. It looks more like 5-transistors. I've been too tired from work to draw the schematic, but I might tackle it on the weekend. Anyway, just at a glance, I see there are 4 SOT-23 style SMD transistors. I'm assuming they really are transistors and not diodes because they are labeled on the PCB as Qxx (plus, there are already SMD diodes on this board and they used the round glass type package). The base of the switcher is connected to the collector of 2 of the SOT-23 transistors, and their both of their emitters are also connected together. However, I don't believe they are 2 in parallel doing the job of one because their bases are not in parallel.
                I pulled one of the SOT-23s because it looked shorted (what a pain). Got it out and it's not actually shorted, but it doesn't measure like a regular NPN or PNP transistor. Assuming this site (http://talkingelectronics.com/projec...eMount-P1.html) is correct about all SOT-23s having the same BCE pinout, I'm getting about 224-ohms between B-to-C and infinity between B-E and C-E. In Diode Check mode, there's 0.3V drop between B-C both directions and infinity between any other pins. That doesn't look to me like any diode or transistor I'm aware of, so I'm guessing it's a bad part? Still looks like there's a short in the circuit somewhere, so something else is either bad or other components are interfering with my multimeter readings.
                There are NO numbers or any kind of markings whatsoever on these SOT-23 parts, so I think the only way I will have a clue as to what they are supposed to be is by drawing a schematic.
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Hm, maybe its a small mosfet?
                  Muh-soggy-knee
                  • b700029
                    Banned
                    • Sep 2010
                    • 640
                    #29
                    Are there really no markings at all, or are they just too small to see?
                    I've found the pure light from a blue LED and viewing obliquely can reveal numbers on parts that otherwise look blank. The markings are often laser-etched and very shallow, so it's more like a faint engraving.
                    The infinite resistance does suggest a MOSFET. Try testing it as if it were one.
                    • cubecompmtdx
                      • Oct 2010
                      • 22
                      Originally posted by retiredcaps
                      I saw a video of this about 1 year ago on the CubeComputerChannel
                      http://www.youtube.com/watch?v=Prmmd1tHV0Y&feature=plcp
                      LOL the ATX100-5, also known as "The Little Fighter."
                      Glad to see you guys experimenting with this power supply. I'm curious to know what the 12v secondary silicon is rated for on this thing. The sticker states 2A for +12v yet my buddy pulled at least 20 outta it... (he did let some magic smoke out and had two extra fans stacked on top of it ) and the unit in my video has been running my 60w (5A minimum) peltier fridge for 9 months non-stop without a problem. The capacitors (I believe JPCE-TUR) in it all appeared fine with no bulging tops. Hopefully you can get the 5VSB fixed on this one because this power supply is apparently underrated. Good Luck!
                      Cube Computer Company - Fulfilling Dreams... One Computer at a Time.
                      Link to CubeComputerChannel on YouTube:
                      http://www.youtube.com/user/CubeComputerChannel
                      • GnatGoSplat
                        • Jul 2011
                        • 50
                        No markings at all, nothing visible, not even under a magnifying glass. I even tried the UV blacklight LED from my A/C leak detecting kit and nothing shows up. I tried scratching at the top in case there's a varnish coating filling in the numbers and making them disappear, but still nothing.
                        I tried this test:
                        http://www.4qdtec.com/mostest.html
                        It does kind of look electrically like a MOSFET turned on, with the 1st 2 pins being source and drain, but even shorting all the pins together doesn't seem to turn the MOSFET off. Also, from what I've found on Google, it looks like SOT-23 MOSFETs should have the pinouts GDS so that makes the voltage drop/low ohms reading between the 1st 2 pins look rather odd.
                        Just to see if that site's testing method is sound, I tried testing a brand new TO-220 MOSFET and was able to reproduce his "good" test.
                        LOL! Yeah, your video made me feel more like I should fix it!
                        The 12V rectifier is a CTX12SL. I can't find a datasheet on that exact part, but I was able to find several websites that say it crosses to a STPR1020CT which is rated for 10A.
                        • cubecompmtdx
                          • Oct 2010
                          • 22
                          LOL so Bestec put in a 10A capable part but slapped a 2A max on the sticker! This part can supply more power than the 100 watts this old thing is rated for! I have another one of these in another computer in storage. It needs some capacitors replaced. I'll make a video of the inside of it whenever I get around to it. One thing that shocks me is the size of those little heatsinks... maybe that's why they put such small ratings on it. But, just hook up a leaf blower Delta fan and you might be able to play Crysis with it
                          • Wester547
                            • Nov 2011
                            • 1268
                            • USA.
                            #33
                            One reason why PSU makes may seem underrating with the specs on the label is because the amount of amps any one schottky (or MOSFET, if you would) can deliver depends heavily on the rest of the components, like the width of the traces, the coils, the switching transistors, the rectifying bridge, the transformer, the topology, the heatsinks, the fan, the capacitors, the other schottky diodes on the other rails, which rail is loaded, etc. If you consider that this PSU is probably limited to 100W max given that Bestecs (not having OPP) explode when significantly more than their rating is pulled overall, even though the part by itself can do 10A (though that too depends on what temperature it's rated at) and maybe even more with good cooling, +12V * 10A = 120W. The +12V rail isn't the only rail in use, naturally, and that Bestec may not even be able to do 120W if the rest of the hardware inside isn't spec'd to deliver such.
                            Without ranting too much, if 100W is the limit of that PSU, you won't be pulling 10A from the +12V rail of that Bestec. Maybe more than 2A, but probably not 10A. With all the rails combined you'll only be able to pull so much. Not to totally discredit what you're saying, though - good PSU makes do overbuild their PSUs and rate their PSU at a continuous and seemingly low rating rather than the honest maximum.
                            • learnmore
                              Help choosing replacement transformer for Levoit 600S SMPS
                              by learnmore
                              Hello Community,
                              I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                              Peace
                              LM...
                              11-04-2025, 09:35 AM
                            • ohren
                              Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                              by ohren
                              Hello!
                              I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                              Measured voltages with no load:
                              After rectifier diodes
                              12V: 6.17 V
                              5V: 5.67 V
                              Secondary transformer pins AC measurement (really don't know if this says anything)
                              12V: 2-2.5 V
                              5V: 1.04 V
                              I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                              03-18-2023, 10:33 AM
                            • mikey5791
                              Is it possible for transformer substitution?
                              by mikey5791
                              Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                              Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                              My questions are
                              1. How do i test to see if the transformer is in good working condition?
                              2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                              Hope you guys understand what i was asking. My intention is...
                              11-03-2022, 02:11 AM
                            • dennis_elx33
                              3PHASE STEP-DOWN Transformer in Check
                              by dennis_elx33
                              Hello All,
                              i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                              Problem statement: Power tripped Off
                              Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                              Action Done:
                              1) Replaced the faulty parts with good spare.
                              2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                              12-02-2024, 06:52 AM
                              ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                              This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              09-06-2024, 04:40 PM
