Re: UC3842 basics
One idea, if someone would please explain.
Suppose one has some transformers, like, one taken from a 5vsb ATX PSU, and from some small smps, say a 5V 2A one.
Knowing the inductance of the coils, and maybe the number of turns in them, could they be used with a 3842 in a circuit to create a different voltage, like 3.3 or 12V ? Just adjusting the values of duty cycle , frequency and the control circuit ?
Or is it that the transformer, in a 3842 circuit, or in others also, always need to be custom dimensioned to that circuit´s parameters ?
Thanks.
UC3842 basics
Re: UC3842 basics
Okay, no hand drawn version but i'm attaching this document. Take a look at the schematic in Figure 6. It shows a forward converter not a flyback but this is not relevant - the wiring of the opto is the main difference.
What they did here is wire the voltage feedback of the 3842 to ground, thus disabling the voltage feedback loop entirely, and using the TL431 as error amplifier. As you see, the collector of the opto drives the Comp pin (the output of the 3842's internal error amp), so it goes straight into the PWM comparator.Leave a comment:
Re: UC3842 basics
I promise a crudely hand drawn version tomorrow.Leave a comment:
Re: UC3842 basics
I have to get off my lazy ass and finish drawing the schematic i have gotten to, because it's pretty different from the one in the first post. I'll do a PCB too.Leave a comment:
Re: UC3842 basics
OK, since the original daigram as shown in post 1 is 150 Ohm, the only 100 Ohm resistor is in the DC output side. Or may be we are not talking about the circuit in post 1, see PDF. I am just confused.
I can see why there are misunderstanding.Attached FilesLast edited by budm; 06-26-2012, 02:03 PM.Leave a comment:
Re: UC3842 basics
If you are getting 5V output for this 5V switching power supply, and if you are using 47 Ohm resistor to limit the LED current and it is burnig up with 5V supply, something does not add up, since 431 will maintain 2.5v, that means the voltage drop across the RLED and LED will be 2.5V. I do not see how you will burn it up.
Or you are designing 5v POWER SUPPLY?
Yes, I am designing a 5v smps just for fun/learning
And I tried 100ohm as in the original schematic, but the smps just starts ticking... 47ohm makes it start up right awayLeave a comment:
Re: UC3842 basics
I think by "feedback winding" he refers to the resistor from the AUX, which powers the 3842. 47 ohms is too much current. It's 150 ohm 0.25W on mine, it does get hot but no smoke.Leave a comment:
Re: UC3842 basics
Or you are designing 5v POWER SUPPLY?Leave a comment:
Re: UC3842 basics
I got the power supply circuit to work, biased the 431 properly, and I get a steady 4.97v output
It does drive a 1A load, the output drops to 4.96v (not much drop). But when I connect the load (a lightbulb) there is a buzzing sound from the transformer, then as the lightbulb lights up, the buzzing/beeping goes away, so the circuit still must be a little unstable.
And the 100ohm resistor (I used 47 ohm) on the feedback keeps smoking, its a 1/2w.Leave a comment:
Re: UC3842 basics
Hi Ben, you need to bias the 431 properly and also the FB for your voltage output requirement.
See attachments and also here:
The example circuit in post1 has so many missing components and circuits to make it work properly, that 431 should have had 1mA bias for it.Last edited by budm; 06-26-2012, 12:56 PM.Leave a comment:
Re: UC3842 basics
I changed the 100 ohm resistor on the feedback winding to a 47 ohm, the opto and 431, and now it does work, but it seems I cant set the output voltage by changing the voltage divider connected the 431's adj pin; it always stays at 4.27v +- 10mV. Adding a load doesn't really do much, and the transformer makes a slight hissing sound.Leave a comment:
Re: UC3842 basics
Mm. Opto and 431 are good? I've had bad 431s make all kinds of odd behavior. A flyback won't work with an output inductor in the feedback loop.Leave a comment:
Re: UC3842 basics
Little pulses on the output means the UC3842 isn't getting the right startup voltage, or it's in current limiting mode when it shouldn't be, due to high parasitics at the mosfet source triggering it. If Vcc of the 3842 is over 12 volts, try increasing the capacitor on pin 3 to 1nF.
And yes the 1nF cap didn't help either.
I tried using an inductor to filter the output but it still didn't work.
tried switching the connections to the feedback winding, but no change whatsoeverLeave a comment:
Re: UC3842 basics
Little pulses on the output means the UC3842 isn't getting the right startup voltage, or it's in current limiting mode when it shouldn't be, due to high parasitics at the mosfet source triggering it. If Vcc of the 3842 is over 12 volts, try increasing the capacitor on pin 3 to 1nF.Leave a comment:
Re: UC3842 basics
I tried increasing the output voltage setting but it still doesn't work. Also adding a minimum load resistor changes the clicking sound to a beeping sound.Leave a comment:
Re: UC3842 basics
Do you actually get anything on the output? Try setting the output progressively higher, until the supply fires up properly. The control method used by this circuit is different than the usual variable-frequency self-oscillating circuit used in a lot of 5vsb designs, so it may not actually go down to 5v stable at zero load.Leave a comment:
Re: UC3842 basics
by tony359Hi all,
I have a CRT (Acorn AKF12, based on the 240V version of the Philips CM8500) which has stopped working. It's making a high pitched noise but not too high. I know this is symptom of a faulty flyback.
What happens when a flyback fails? I see that the main voltages out of the PSU are not reaching rated values, as if there is a short.
There are supposed to be 125V/26.5V/15.5V outputs but I am reading something like 48V, 10V and 8V. If I unplug the PSU from the rest of the PCB, I can measure the expected values.
Can it be a short somewhere... -
by прямоSo I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...3 Photos -
Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
Any ideas where to go next? -
by mrcliemHello...
I got my self a dead CM V700 PSU, with nothing on +5vsb
I have tried to fix it for the past 2 week, and I'm stuck... so i guess i post it here to get some pointer before i scrap it..
As you can see in photo, the psu still pretty clean, no visible damage or bulging cap.. when i got it, it still has CM seal on it
The +5vsb system use ICE2QR4765, I have trace and measure the voltage on ICE2QR4765 and the only voltage reading i got is in VCC 4.8v, Drain 310v and FB 3v.
I have read the datasheet and and still can not... -
by socketaRescued this one
Started it up in the computer case, and noticed that it would shut down after about 10s in the BIOS
Took it out, connected to hard drive and it loses all power on all rails (except for 5VSB) after about 40s or so. (the same result happens without a hard drive connected)
The 5VSB drops to 2.5V when it 'shuts down'
And the voltage across the primary cap falls from 335V to 330V at the same moment
I think that the 5VSB is regulated by an A6069H PWM chip (which was initially dropping to 2.5V even before the the PS-ON was grounded - but it now stays at... - Loading...
