Whats wrong with these stupdi apple adapters?!
  • Behemot
    • 4845
    • CZ
    Got this iPad with the word it charges only to some 16 %. Based on search, it looks like these fucking adapters go bad like hell. It looks like they have insufficient power to charge beyond some point.
    What the heck, doesn't this crap cost so much they can at least bundle that with some charges which wont go to hell after few weeks?
    Anybody already tried to discover what the problem is? Are they using some cheapo generic crap PSU's capable of delivering 0,1-2,1 A depending on luck or the actuall mood of these things?
  • PeteS in CA
    • Aug 2005
    • 3580
    • USA, Unsure of Planet
    Re: Whats wrong with these stupdi apple adapters?!
    Sounds more like an issue with the charge control circuit, which I would expect to be in the iPad. Apple used to be pretty fussy about requiring power supply vendors to use good quality caps and such. And their power group had pretty good engineers and techs. That was a while ago, though.
    PeteS in CA
    • Behemot
      • 4845
      • CZ
      Yeah, this looks like the case. Although I really found quite a number of people with the same problem solving it by using new adapter, here it does not help, it still stops at 16 % charge.
      Will have to find some guide how to open that. Do you think it will have separate circuitry? It may have because of the cells soldered inside directly, although most of these batteries have the controller directly on their body thus changing only cells may help.
      • PeteS in CA
        • Aug 2005
        • 3580
        I'm not much of a Gadgeterian (and am a bit Deciduo-phobic), so my best suggestions are to see if Apple has a SW update for the iPad, and if not, contact their tech support (or visit an Apple Store if there is one near you that has in-store tech support). Also, there may be a problem with the batteries no longer taking a charge.
        Stupid question (sometimes electronics do "stupid" things) ... I assume you are seeing a message that the battery is at 16%, but does it really shut down in a time consistent with that message?
        PeteS in CA
        • Behemot
          • 4845
          • CZ
          Well when I got that it displayed something about low charge, it was arround 5 % IIRC. I have seen it charging up to 16 % so I guess something is damaged there.
          Original service would be expensive, I am sure of that. Yeah, owner of this thing IS stupid for doing uncertified repair when it STILL WAS under warranty. But the damage is done, now I can only offer cheaper repair or suggest expensive apple service center.
          • rogfanther
            • Jul 2006
            • 458
            • Brazil
            based in some limited experience with apple notebooks, I wouldn´t put past the adapter to be weak after some time of use. If you can find another to make a test, you could eliminate that possibility.
            • digge
              • Apr 2006
              • 296
              If they have more then one cell in series it might be that one cell have gone bad, that might keep it from charging over the 16%.
              Just a guess of coarse, just throwing it out there.
              • Behemot
                • 4845
                • CZ
                Well it is 3,6 V in 3 pieces, so either every one is 1,2 V in series, or (more likely) each one has three cells in series, totaling in 9 cells. That's close to 16 %.
                rog: already wrote I tried different adapter, still stops at 16 %.
                  No, it is two 3.7V Li-Ion cells in parallel.
                  • Behemot
                    • 4845
                    • CZ
                    First generation got two-cells of 3,7 V, this one has three 3,8V cells. But yeah, it seems Li-Pol has native voltage of arround 3,7 V so these are whole cells, nothing small packed inside them.
                    • shovenose
                      Send Doge Memes
                      • Aug 2010
                      • 6575
                      Well...
                      Apple adapters have NEVER been reliable!
                      • SIDMX
                        • Nov 2010
                        • 165
                        • Mexico
                        I think digge's post maybe correct and the problem might be with the battery or the circuitry inside the battery pack and not the charger, I have seen several times before this same problem in laptops, notebooks and netbooks, all of them refused to fully recharge the batteries and get stuck at some % point, new batteries resolved the problem in all of them so try with another battery and see if that makes it.
                        • Behemot
                          • 4845
                          • CZ
                          Yeah. I think I will suggest professional service for the owner, they are not THAT much pricier (I can do it for like over 1000 CZK, service gets like 2000). The thing is, they do it all the time, I never opened this thing and acording to manuals many things can go wrong. In the end I can ass well be the one who will pay damaged ipad…
                          • a_p3rson
                            Apple Watch Charging Controller Schematics / Boardview - 820-02601
                            by a_p3rson
                            Hi there,
                            I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
                            You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
                            This daughterboard uses an interesting...
                            04-21-2025, 11:41 PM
                            HP ProDesk 600 G5 + Apple AirPods ProDesk 600 i7-9700 Specification for Upgrade or Repair
                            This specification for the HP ProDesk 600 G5 + Apple AirPods can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Apple AirPods boardview and ProDesk 600 G5 + Apple AirPods schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                            09-12-2024, 02:30 PM
                            HP ProBook 430 G7 + Apple AirPods Pro Notebook 400 Specification for Upgrade or Repair
                            This specification for the HP ProBook 430 G7 + Apple AirPods Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + Apple AirPods Pro boardview and 430 G7 + Apple AirPods Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                            09-06-2024, 07:50 PM
                            HP EliteBook 830 G6 + Apple AirPods Pro Notebook 800 Specification for Upgrade or Repair
                            This specification for the HP EliteBook 830 G6 + Apple AirPods Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G6 + Apple AirPods Pro boardview and 830 G6 + Apple AirPods Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
