Okay, so another eBay bargain. Got two DPS-1200B's for £5.98, including shipping.
These give 98A on 12V each, as well as 5Vsb at 0.1A. Both are new in open box. They are rated only for 200 - 240V input, I guess because they would pull too much from a 115V input
Who wants to see inside these?
Challenge here is to figure out how to turn them on... I'm probably going to have to hard-wire in a signal to the PWM controller, as I believe it has an MCU in it (appears to have some kind of SMBus interface from reading up on the 'net... and the number of pins on the control connector does not look trivial.)
Also they have no fans, so they will have to be externally cooled. I plan to use these near their rated power at times, so the cooling will have to be good. Probably two 120mm fans. They will be in parallel to give 196A at 12V. I also plan to see if I can mod them to 13.2-14V output, but 12V will still be okay for my application.
.Who wants to see inside these?
