Giant FSP Resistors
  • mockingbird
    • Dec 2008
    • 5488
    Giant FSP Resistors
    What are these gigantic pink resistors FSP used to use in some of their PSUs?
    This one comes from an AOpen branded FSP250-60GTW.
    The colors are, from top to bottom:Red (Auburn), Green, Brown, Gold.
    See attachment for larger image.
    Re: Giant FSP Resistors
    From their position (secondary side) they are probably minimum load resistors, which provide a small amount of load to the power supply allowing it to start with little or no external load.
    • mockingbird
      • Dec 2008
      • 5488
      I have another one where some of the thin ceramic has chipped off exposing metal underneath... Is there something of higher quality I can replace these with?
      • mariushm
        • May 2011
        • 3799
        That resistor seems to be a 250 ohm one based on the colors you say, probably 5-10w based on the size.
        As it's already said, it's there to provide a minimum load for the power supply, it helps it stabilize the voltages when very little is attached to it, or when in standby for example, when only the 5VSB is used.
        There are various packages, for example wirewound resistors in ceramic package (acting as a heatsink) :
        or thick film resistors that look like this:
        (but these would be bad for you as the wires are much closer in the fsp power supply)
        You can find them on Digikey easily.
        • PeteS in CA
          • Aug 2005
          • 3586
          • USA, Unsure of Planet
          I'm going to guess that the first color is actually brown, which would make it 150 ohms, a standard 5% value (220, 240 and 270 are standard values, but not 250). Actually, the more I think about it, I wonder if the third band (multiplier) might be black, a 15 ohm resistor (or even red-black-gold-gold, a 2 ohm part). I'm going to guess that it is metal oxide film, 5W; I could be wrong, but I don't think that technology/package goes up to 7W or 10W.
          Love those vertical-mount bathtub types mariushm had in his post! Good PCB real estate efficiency, nice cooling air profile. They can be found in 2W, 3W, 5W, 7W and 10W, wire-wound for lower values, and metal oxide film for higher values. Cheaper ones are wire-wound (or film) on a fiber glass core; better ones have a ceramic core. The other ones are in the TO-220 package and need a heatsink to be able to dissipate their rated power.
          PeteS in CA
          • mockingbird
            • Dec 2008
            • 5488
            I think this is the closest. It hink it's supposed to be brown black gold gold the more I look at it. This would make it a 1 Ohm Resistor. Does this make any sense? Maybe it's just big because of a high watt rating?
              Why not lift one leg and test it?
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                +1
                I regularly replace those minimum load resistors if they dissipate more than 0.5W of power - it's just a waste of power, hurts the overall efficiency, and cooks nearby caps if there are any. If the resistors had low values, generally I try to use 33 to 50 Ohms for 3.3V rail, 50 to 100 Ohms for 5V rail and 5vsb, and 330 Ohms or more for 12V and -12V rails, all 1W parts minimum (or at least 2x the power they will be disippating).
                If a power supply has such huge load resistors, then the designer must have been too lazy to design a proper control loop. Most reputable power supplies have very small load resistors, and they are usually of high resistance too so they don't waste power.
                • PeteS in CA
                  • Aug 2005
                  • 3586
                  I thought of 1 ohm as a possibility, but on a 3.3V O/P that would be throwing away 10W, a big waste of power, putting a lot of heat near lytic caps, and if they are using a 10W part to dissipate 10W, that is beyond !
                  PeteS in CA
                  • AJ847.63e
                    Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                    by AJ847.63e
                    Hi Folks,
                    Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                    I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                    The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                    05-06-2025, 10:37 PM
                  • TinkerTron
                    Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                    by TinkerTron
                    Hey everyone,
                    I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                    Instead, here's what's been bugging me so far:
                    The schematic...
                    03-06-2025, 02:03 PM
                    HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                    This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                    09-12-2024, 02:20 PM
                    HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                    This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                    09-06-2024, 10:56 AM
                    HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                    This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
