OCZ technology OCZ500SXS PS
  • sandrabrnelic
    • Mar 2012
    • 34
    • Croatia
    Hi !
    I'm new here on forum and i hope i can learn something about PS repair from experienced people here.
    My problem is PS from title. It's OCZ but inside is FSP group FSP500-60GLY(NEW2) board. The problem is that 12V and 5V outputs are to low when PS is under load. 5V is low (4.6V) even without load. I have changed all caps at 5V and 12V outputs but problem is still there. I have checked shottkey diodes at output and they are all ok. What should i check next ?
  • 999999999
    • Sep 2006
    • 774
    Re: OCZ technology OCZ500SXS PS
    Has it always been like this? I mean is it new and arrived like this or did it work previously, and is it possible it worked previously meaning it powered a system but was always too low on 5V & 12V rails?
    Might just be a pot contact or misadjustment issue.
    There is a potentiometer inside in front of the transoformer, yes? It has a little orange adjustment screw, use a fine tipped marker to mark the screw and body of the pot to indicate what it's initial dial position was, then turn it back and forth several times with power OFF. Next with it on by jumpering the connector green PS_On signal to a black ground wire, turn the pot slightly one way and/or the other while reading the voltages.
    I suggest doing this without it connected to a computer to make sure all rails (not just 5V and 12V, but especially also 3.3V) are within spec before hooking it up to the computer again to do load testing to more finely tune the adjustment of the pot.
    Ideally you would use an insulated screwdriver since there's live mains + high DC voltage present. Be careful.
    • sandrabrnelic
      • Mar 2012
      • 34
      • Croatia
      It was working previously, but it started to make problems. PC began to have problems and started to reset itself in the middle of work without obvious reason. And later it had problems even to start. After i have realised it's PS problem i have changed PS but since i have some experience in electronics i have decided to learn something about power supplyes ... so i'm here now.
      Regarding a potentiometer contact i think it is ok because i forgot to mention that PS outputs are not stable (they oscillate +/- 0,3V). I have tried to move pot and it can rise 5V voltage to 5V but only when i turn it full to the end but voltages are not stable. Problem must be somewhere else. I will look at outputs with scope later (when i get it) so maybe this will help ...
      Thank you for your efforts, and forgive me for my crappy english.
        Your English is better than my Croatian!
        What brands of capacitor are used in the power supply?
        • sandrabrnelic
          • Mar 2012
          • 34
          • Croatia
          Capxon
            Originally posted by sandrabrnelic
            Capxon
            That could be your problem, do any feel like they are not flat (bulging) when you touch them?
            • c_hegge
              • Sep 2009
              • 5219
              he said he already replaced them (at least for the rails in question).
                Hmm, did he replace good caps with CapXon, or CapXon with good caps?
                • PeteS in CA
                  • Aug 2005
                  • 3583
                  • USA, Unsure of Planet
                  What frequency are the O/Ps "oscillating" at? If at 100Hz, then the I/P caps are a likely cause.
                  PeteS in CA
                  • sandrabrnelic
                    • Mar 2012
                    • 34
                    • Croatia
                    .... 4 months later ....
                    Thank you Pete, it was just like you said
                    In the meantime i have built C/ESR meter which helps me a lot to detect dead caps ...
                    I have found dead Taepo on primary side (100uF/25V). Changed it and my OCZ is again working like new one.
                    • Rulycat
                      • Apr 2010
                      • 724
                      You wouldn't mind sharing how you built the ESR meter, would you?
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        Theres a few circuits on the web, namely this one.
                        Muh-soggy-knee
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          Originally posted by PhilipWinkel
                          bumb ubm!
                          Wut?
                          Muh-soggy-knee
                            HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                            This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                            09-12-2024, 02:20 PM
                            HP Z440 Workstation E5-1620V4 Specification for Upgrade or Repair
                            This specification for the HP Z440 Workstation can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z440 Workstation boardview and Z440 Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                            09-12-2024, 03:44 PM
                            HP EliteDesk 800 35W G2 EliteDesk 800 i5-6500T Specification for Upgrade or Repair
                            This specification for the HP EliteDesk 800 35W G2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 35W G2 boardview and EliteDesk 800 35W G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                            09-12-2024, 03:36 PM
                            HP Z440 E5-1620V3 Specification for Upgrade or Repair
                            This specification for the HP Z440 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z440 boardview and Z440 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP Z440 is accurate, safe, error...
                            09-12-2024, 03:30 PM
                            HP Z440 E5-1650V3 Specification for Upgrade or Repair
