Alternative req'd for wet tantalum axial caps
  • Richie_asg1
    • Feb 2009
    • 21
    Hi folks,
    I'm just sorting out a military radio built around 1970 with a failed PSU. This seems to be a common trend on this model. Problem I'm having is finding a replacement for the caps they've used which are axial 3.6uf 150Vdc wet tantalum with a metal can and red glass seal.
    The thing is - a lot has happened since 1970, so is there a better alternative out there now - in this odball size?
    The equipment is all sealed up and dry but can get quite hot, and these have lasted 40 years - will modern electrolytics last that long?
    Similar types in the HF end - would the alternatives be suitable here as well?
    Many thanks to this great forum.
    Richie.
  • 999999999
    • Sep 2006
    • 774
    Re: Alternative req'd for wet tantalum axial caps
    In that size I'd try a film cap. Go with electrolytics only if the capacitance value is high enough that cost or space prohibits using another type. Try to determine if the 3.6uF is a critical frequency/timing value or if something close would work.
    If voltage is low enough on the HF end you can use modern dry tantalums or polymer caps... probably axial or radial leaded on something that old. Depends on the specific cap specs needed.
    If it doesn't "need" to be all sealed up for your use or purposes you might consider modifying it for more ventilation even if it just means adding some passive cooling holes here and there.
    • Richie_asg1
      • Feb 2009
      • 21
      Thank you for the quick reply. I have repaired some valve based equipment that had perfectly happy yellow polyester film caps in there so this looks good. The psu in the radio only has to supply 4 voltages from a 24v battery, but one of those is 110v with an inverter. I think it overshoots a bit then is regulated back down to the 110v. Without detail I think the electrolytics are there as smoothing caps on the 110v rail to 0v, and there are some more in the oscillator module just to keep things clean.
      Is there any problem with using non polarised capacitors in place of electrolytics to remove ripple from the supply?
      I think I'll try and keep to the values in the oscillator circuit if replacements are needed.
      Everything is overprotected in this radio and they spent a lot of money making it EMP hardened. Don't really want to cut holes in it as it is water resistant to a metre for 2 hours minimum - I reccon more. It was pressurised when I opened it.
      • 999999999
        • Sep 2006
        • 774
        NP caps can be used for supply ripple w/o problems.
        • Richie_asg1
          • Feb 2009
          • 21
          Cheers, will try them and see. Can't be worse than dead can it Although they did make use of the small size components, they put them in larger screened units anyway, so should get away with it.
          Many thanks.
          R.
          • 999999999
            • Sep 2006
            • 774
            Keep in mind that with seals that old, it may not be as water resistant anymore after it's reassembled. Depending on seal type I might coat them with silicone grease, or add some non-permanent, peel-away type gasket sealant.
            • ChaosLegionnaire
              cracked tantalum cap on a video card. safe to apply power without fireworks?
              by ChaosLegionnaire
              please refer to the attached pics. is it safe to apply power with that tantalum cap like that without causing fireworks? i dont wanna burn a hole through the pcb as the gpu chip is on the other side.
              happened to me once before with a shorted mlcc. shorted mlcc on a vrm power phase burned a hole through the pcb power section but thankfully that was nowhere near the gpu chip. but the video card still ended up in the landfill anyway tho as the burn-through was not fixable.
              so do let me know what u think of the chipped tantalum there. thanks....
              09-08-2024, 07:05 PM
            • baxmax
              alternative diode to Samsung TV 55 mb
              by baxmax
              Hi, Recently my Samsung 4K QE55Q60AAUXXH just suddenly stopped working_ there is no any sign of life - no red light or anything..and think, after diagnostic, it is diode DM863c SF28e PK33 siyu or one of these four. Is there any alternative I can replace with since it is hard to find it in my country and to order outside is quite difficult. thank you...
              10-21-2024, 07:35 AM
            • omgitdrifty
              Axial Resistors help
              by omgitdrifty
              Hello all hope you all well
              I just want to make sure I got this right.
              This is 150 Ohms 5% Axial Resistors
              Brown Green Brown Gold
              Please let me know.
              Many Thanks
              David...
              10-04-2024, 08:21 AM
            • Norrecito
              iPod nano G3 - alternative soldering point for the white battery wire
              by Norrecito
              A friend of mine gave me an iPod nano G3 to see if I can fix it for him.
              The device had a faulty battery and he tried to replace it but failed. In the process he managed to pull off the pads that corresponds to the white battery wire (marked with a red circle in the images)....from both sides of the PCB. Fortunetely he didn't damage anything else.
              This is usually an easy fix HOWEVER, on the PCB, I see no traces coming from the VIA and after searching the internet, I've found no schematics nor boardview for this device. With the pads gone from both sides I seem...
              09-07-2024, 03:54 AM
            • jrutla2
              Help Identifying a Tantalum Capactior!!!!! 68 C79 Please help!!
              by jrutla2
              Hello BadCaps Forum! I'm new to the group and hope you guys can help me with something. I have a 2017 Apple imac A1419 board # 820-00609-A that i'm trying to identify a capacitor failure on. The capacitor is a tantalum 68 C79. See pic attached. I've tried to figure this out using the web and unfortunately can't find the information. Can someone tell me what the Capacitance value, voltage, etc is for these 68 C79 caps are? Where could i pick up a replacement? Thanks in advance!!...
              05-03-2024, 04:00 PM
