DPS-200PB-138C - damaged solder pad
  • seanc
    • Nov 2008
    • 1319
    I have a Delta DPS-200PB-138C.
    Decided to give it a re-cap.
    I've lost a solder pad, I need to know where I connect a capacitor to.
    The capacitor in question is a 47uf 50v (Panasonic FC), with a 100uf 25v (Panasonic FM) capacitor to its right and a 1uf 50V (Nichion) behind it.
    Pictures of the top, bottom, layout of capacitors and damage are attached.
    If someone can give me a hand, it's appreciated. I've not learned how to trace circuits yet. It looks like I could connect it to the leg which is above, to the left - C16 on the top side.
  • TheLaw
    • Jan 2011
    • 477
    Re: DPS-200PB-138C - damaged solder pad
    I'm having a hard time determining exactly where the traces are going. You have good pictures. If you could zoom in a little more, it would be a lot more helpful. If not, you'll just have to tell us.
    To help, I put in some reference colors on your picture (located in the attachments)
    Look at the exposed beige colored board that was left when you lifted the solder pad...Don't look at my picture to actually determine it. Use the actual board for that.
    Does the beige make contact with the red or blue solder joint. You can probably tell that the solder pad is surrounded by green soldermask. However, by looking at your picture, it seems that the exposed board makes contact with the red solder joint, and possibly the blue solder joint.
    If the beige/tan touches either one of those solder joints, then effectively, the Panasonic FC capacitor is also connected to that solder joint. If that is the case, then you can simply solder the leg of the Panasonic FC to the other solder joint, and you have effectively fixed it.
    This is pretty hard to explain...actually. But the fix itself is very easy. Don't panic. I've done this with a crappy amplifier board, where I pulled 10+ pads and fixed them with no problems...until I had a grounding problem and screwed something over... Tell me if you have questions. I'll try to reword if need be.
    • seanc
      • Nov 2008
      • 1319
      It looks to me like it does make contact with the red joint, the blue one is very close too.
      I had it joined to the blue joint but wasn't sure so I un-did it, took pictures and came here to ask for help
      I'll try and take another picture zoomed in tomorrow.
      • yyonline
        • Jul 2009
        • 692
        It looks like the blue and red joints are both connected to the same copper plane. Measure between the blue and red joints with an ohmmeter. If you get 0 ohms resistance, it doesn't matter which one you solder the leg to.
        • Wizard
          • Mar 2008
          • 2296
          THis is a solder pad island. Jumper wire goes over to the right.
          Check the solder pad that is for jumper wire is ground as this cap that was soldered to the other track on capacitor's negative side.
          Cheers, Wizard
          • seanc
            • Nov 2008
            • 1319
            Cheers guys, it's up and running
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • Nagyesz
              Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
              by Nagyesz
              I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
              All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
              How can I extend its lifespan? Could reflow help?
              It has ryzen 5 5500h, rtx 2050, no soldered ram.
              Example of the artifacts:
              03-01-2025, 11:11 AM
            • Mirenia
              Acer Helios 500 (PH517-51) - unexpected reboots when laptop is warm (cold solder joint issue?)
              by Mirenia
              got an Acer Helios 500 Laptop (PH517-51) for diagnosing with a strange issue:
              The laptop runs for a while (1-2 hours, sometimes less) and then suddenly shuts completely off, like someone pulled the power cord and restarts immediately after on its own.
              If this happened once, then the laptop only runs for a few minutes until restart.
              This happens regardless while staying in windows or uefi or in a linux environment.
              At first I thought of a normal overheating issue, but as I monitored temps with HWInfo64, nothing seems very hot.
              01-05-2025, 05:15 PM
            • BigPete
              Panasonic Heatpump Dryer Repair
              by BigPete
              I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
              The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
              In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
              Unfortunately the whole machine has to come apart to fix it.
              I have...
              11-01-2025, 06:40 PM
            • Andre Gilbert
              by Andre Gilbert
              Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
              Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
              11-20-2024, 08:52 PM
