The PSU FAQ
This is a sticky topic.
  • Behemot
    • 4845
    • CZ
    #41
    Re: The PSU FAQ
    up?
    • PeteS in CA
      • Aug 2005
      • 3586
      • USA, Unsure of Planet
      #42
      Re: The PSU FAQ
      It's probably way late to respond, but there are 4 rectifiers in a bridge rectifier. Two conduct during one half of the AC cycle, and the other 2 during the other half cycle. Thus the filter cap(s) get charged during the full cycle, or the full wave. Hence the name "full wave bridge bridge".
      PeteS in CA
      • Behemot
        • 4845
        • CZ
        #43
        Re: The PSU FAQ
        I meant the secondary rectifiers, there is no full bridge being used, just two diodes with common output. In every cycle, just one diode is used, yes? But I have learnt there is also something called duty cycle, so, in reality every diode is able to rectify all the power of the whle rectifier because after short time the second diode will do the rectifying. The first could "rest" in this time, and otherwise, right?
        • PeteS in CA
          • Aug 2005
          • 3586
          #44
          Re: The PSU FAQ
          Ah, sorry for misunderstanding. The answer depends on the topology, whether it's a forward converter or a half- or full-bridge.
          In a bridge topology current flows through the transformer primary winding one way then the other in alternating half-cycles (with "dead time" in between each half cycle of conduction). The secondaries are center-tapped, with that center tap being output return. The ends of the winding each have a rectifier (or one of the rectifiers in a dual rectifier), which conduct in alternating cycles.
          In a forward converter current flows through the transformer primary winding in just one direction. So you have an "on" time and an "off". This simplified schematic on Wikipedia shows how the output rectifiers are connected in a forward converter. There is one rectifier (or half of a dual), D1, that conducts during the "on" time, charging the output inductor through the load and back to the other end of the winding. During the "off" time, the transformer and D1 are not active, but the inductor is charged and able to provide current to the load. The second rectifier, D2, is connected to complete that current path. During "off" time, current flows out of the inductor, through the load to the output return, from return into the second rectifier, and through the rectifier into the other end of the inductor. The current through the inductor is "continuous". It is either being charged while current is also being supplied to the load or partly discharging to supply current to the load. Thus, the output inductor averages the rectified voltage pulses to supply a continuous current to the load, resulting in a DC voltage.
          PeteS in CA
          • Behemot
            • 4845
            • CZ
            #45
            Re: The PSU FAQ
            I see, thanks for explaining this :-) In both modes icreasing the switching frequency means increasing forwarded power, right? In first, there are shorter dead times, in the second, power is pumped more often to the inductor.
            Anyway, the fact that the single diodes are able to let the same amount of current through as is the maximum of whole device (two diodes in parallel) is conected with the duty cycle, right?
            • JonathanAnon
              • Jul 2012
              • 457
              • Ireland
              #46
              Re: The PSU FAQ
              Would it be handy to try to find an image of some basic switch mode power supply and try to mark out on it all of the areas that are referred to in the original post... It would be easier to visualize the different sections.. I'd draw it up in Photoshop...
              • joshnz
                • Feb 2011
                • 969
                • New Zealand
                #47
                Re: The PSU FAQ
                Duty cycle refers to the on time
                almost all switching power supply's use this method to control the output most have a maximum duty cycle of 80% due to core saturation that means the transformer core or inductor core has reached the maximum of magnetic flux it can hold.
                My pc
                CPU : AMD PHENOM II x4 @ 3.5Ghz
                MB : ASUS M4A89TD PRO USB3
                RAM : Kingston ValueRAM 16gb DDR3
                PSU : Cooler Master 850W Silent Pro
                GPU : ATI Radeon HD 6850
                • Behemot
                  • 4845
                  • CZ
                  #48
                  Re: The PSU FAQ
                  Yep, but as there are two diodes in the bridge topology (with double the secondary wiring on transformer and return pin), when one has duty cycle of e. g. 30 %, the other gets the 70 %, right? So in all they have 100 % and can do twice the current per diode (means, total output power equals to power of device).
                  • joshnz
                    • Feb 2011
                    • 969
                    • New Zealand
                    #49
                    Re: The PSU FAQ
                    no they both will get 30% given to them 30% on one half of the cycle and 30% on the other. this setup doubles the the number of output pulses giving more stable voltage and higher output current.
                    If I have my schematic soft on this machine I could explain it better.
                    My pc
                    • Behemot
                      • 4845
                      • CZ
                      #50
                      Re: The PSU FAQ
                      So when one half of the wiring gets high pulse, the other one gets the same low, but with reversed polarity, so basically both get the same (two minus give plus)?
                      • joshnz
                        • Feb 2011
                        • 969
                        • New Zealand
                        #51
                        Re: The PSU FAQ
                        in my attachment you can see how the two halfs are prossesed
                        excuse my crude drawing done it in paint
                        also i made a error in the pic d1 and d2 are the same part.
                        My pc
                        • joshnz
                          • Feb 2011
                          • 969
                          • New Zealand
                          #52
                          Re: The PSU FAQ
                          this is another way it is done you double the diodes current capacity but only one output pulse per cycle and the winding on the transformer carry's twice the current if was run at the same frequency.
                          My pc
                          • Behemot
                            • 4845
                            • CZ
                            #53
                            Re: The PSU FAQ
                            So there is also common wire on the primary, I see. It clears a lot of things now
                            EDIT: and theres also famous push-pull.
                            • itwentboom
                              • Sep 2012
                              • 6
                              • England
                              #54
                              Re: The PSU FAQ
                              Not sure if to mention this here, but it is interesting to note most of the computer SMPSUs come from Taiwan/China. I can see the economics of manufacture of the far east but do they do the design and development too?
                              I'm in the UK and trying to design/manufacture in this country is usually not a good idea, just the usual costs of.
                              • Behemot
                                • 4845
                                • CZ
                                #55
                                Re: The PSU FAQ
                                Yes, majority of worldwide successful companies producing good PSU's are Taiwan based. Just a couple (actually ) is from USA I think. Maybe few more I am not so familiar with too.
                                • german318
                                  • Feb 2014
                                  • Argentina
                                  #56
                                  Re: The PSU FAQ
                                  Thanks for the info
                                    HP Pavilion Wave Pavilion Wave Desktop - 600-a030na Pavilion Wave i3-6100T Specification for Upgrade or Repair
                                    This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a030na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                    09-12-2024, 03:44 PM
                                    HP Pavilion Wave Pavilion Wave Desktop - 600-a103na Pavilion Wave i3-7100T Specification for Upgrade or Repair
                                    This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a103na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a103na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a103na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                    09-12-2024, 02:00 PM
                                  • FrancescoV
                                    Onkyo HT-R390 no sound output, video output ok
                                    by FrancescoV
                                    Good morning everyone,
                                    I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                    The firmware reported is the following:
                                    M:1.00/11107BLP
                                    D:?.??/????????
                                    O:1.00/11107AL
                                    The DSP firmware given the question marks seems corrupt.
                                    On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                    05-11-2025, 02:59 AM
                                    HP Pavilion Wave 600-a055cn Pavilion Wave i5-6500T Specification for Upgrade or Repair
                                    This specification for the HP Pavilion Wave 600-a055cn can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave 600-a055cn boardview and Pavilion Wave 600-a055cn schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                    HP Pavilion Wave 600-a102ng Pavilion Wave i3-7100T Specification for Upgrade or Repair
                                    This specification for the HP Pavilion Wave 600-a102ng can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave 600-a102ng boardview and Pavilion Wave 600-a102ng schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
