another G5/661-3350 query
  • jetadm123
    • 2169
    Re: another G5/661-3350 query
    Unfortunately, we have become a "board swapping" society. In theory, because of the cost of labor, it's cheaper (and more profitable) to swap boards than to troubleshoot down to the component level. Also, instead of repairing and with the price of electronics so low, many consumers will for a bit more money, opt to purchase a new unit with factory warranty.
    • SoporteHR
      • Sep 2018
      • 80
      • Venezuela
      Re: another G5/661-3350 query Diode T2D47
      hello to all.
      Today I got a source of API power. it receives the voltage of 300 vdc, but it does not start. In the output I do not have the 5 volts of the purple or green cable.
      I tested the diodes of the secondary and mosfet of the primary power and they are fine, I found the diode T2D47 (D4) open. What happens if this diode is open? Can it cause the source not to start?
      Another doubt as it would be to perform the measurements with line voltage for the IC TNY276P UC3842A so as not to damage them or damage the multimeter
      The power source is an API2PC23. P / N: 49P2149.
      Thanks in advance for your collaboration.
      Idioma Natal:
      Hoy me llego una fuente de poder API. la misma recibe el voltaje de 300 vdc, pero no arranca. En la salida no tengo los 5 voltios del cable morado ni verde.
      Probé los diodos del secundario y mosfet del primario de potencia y estan bien, encontré el diodo T2D47 (D4) abierto. ¿que sucede si este diodo esta abierto? ¿puede casusar que la fuente no arranque?
      Otra duda como sería realizar las mediciones con tensión de linea para los IC TNY276P UC3842A para no dañarlos ni dañar el multimetro
      La fuente de poder es una API2PC23. P/N: 49P2149.
      Gracias de antemano por su colaboración.
      • caspian
        What Zener Diodes on a Linear Power Supply
        by caspian
        Dear members,
        I have a linear variable power supply with unknown brand name that I used for voltage injection.
        Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
        In addition, I discovered that its zener diodes are defective.
        I can replace the burned transistors.
        But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
        Therefore, I cannot replace the zener diodes.
        I do not want to test the zener diodes in a test circuit to discover their model or value.
        no schematics are available...
        05-26-2025, 12:38 PM
      • nev1001
        What zener diode might fix the sound on Maestro Mayhem gaming chair?
        by nev1001
        Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
        The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
        It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
        I think an issue could be a zener diode (or capacitor) which has shorted out.
        The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
        04-17-2025, 05:09 PM
        NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
        I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
        I bought this from an eBay seller but unfortunately they only had one
        I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
        I bought three of from them to also make battery packs with this output power limit in mind
        I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
        04-23-2025, 05:50 AM
      • unimatrix93
        TV backlight zener diode
        by unimatrix93
        Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
        So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
        Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
        The led strips has 9 6V leds.
        02-10-2025, 12:13 PM
      • Vincenzo2
        Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
        by Vincenzo2
        My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
        Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
        I put some pictures here to show that it is labeled "M7"....
        09-07-2023, 07:43 PM
