Troubleshoot desktop computer with Gigabyte P750GM PSU
  • Adenitz
    • Jan 2021
    • 122
    • Congo
    Hello guys,
    I have a problem with a desktop computer that cannot start (cannot turn on when pressing the power switch).
    I know for sure that power supply is Gigabyte P750 GM, but I cannot tell the manufacturer of the motherboard (LGA 1331). All I can read is the following number on the sticker: 706023 - 01460 - MB1180 - b05 1407.
    Motherboard is most likely Gigabyte X570 AM4
    The problem is that computer cannot start when power switch is pressed.
    So I first tested the PSU. I have plugged out ATX 24 pin power connector from the board and use paper clip to short pins 16 and 17. When I do this, PSU starts and I can measure all voltages (3.31 V, 5.01V, 11.99V). They seem stable. So at first I suspected motherboard, but then I noticed something that I find odd.
    When power cable is unplugged, each time I connect pins 16 and 17, there is a clear click sound inside the PSU.
    The owner of the PC says it didn't die suddenly. Two or three times before this happened, computer also didn't start, but it needed a few times pressing power switch to start.
    I have tested the power switch (multimeter in continuity mode) and it works OK. Each time I pressed power switch, the resistance between to leads drop to 0.1 ohm.
    Can you advise me what to try next? I would try to test it with another PSU, but I'm interested to learn if this clicking sound in the PSU (with no power) OK when shorting pins 16 and 17?
    Thank you.
  • Adenitz
    • Jan 2021
    • 122
    • Congo
    Re: Troubleshoot desktop computer with P750GM PSU
    Here is the update.
    When testing with other PSU, computer started without problems.
    So PSU is to blame even though it is old a little less than 3 years.
    When cover is removed, there are two bulged capacitors visible.
    One cap is 1000 uF, 10V, other is 2200 uF, 10V.
    I will replace them and hope for the best.
    Just want to say that testing PSU by shorting pins 16 and 17 together is not 100% reliable, because I could measure all voltages and they were stable at nominal values. This PSU could also power chassis fans but this was not enough to start the computer with a Nvidia RTX 175 W graphics card.
    Attached is a picture, does anybody can say what these two caps are used for. Since they are 10V rated, they are probably on 5V or 3.3V output line.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Most likely they are for the separate 5VSB power supply.
      Notice their proximity to that small transformer and what I would imagine is a 8-pin 5VSB control IC right next to it.
      • Adenitz
        • Jan 2021
        • 122
        • Congo
        Ok,
        so because this is for 5V standby, that is the reason why PC cannot even start and doesn't show any signs of life when pressing power switch.
        I have found this article, but this PSU serial doesn't belong to the specified range, so it doesn't qualify for the RMA.
        Nevertheless, I think it's a shame that PSU works only 4 months after warranty period is elapsed.
        BTW, this thread should probably be moved to PSU subforum.
          • 31161
          Re: Troubleshoot desktop computer with Gigabyte P750GM PSU
          when you replace them, replace the other one with the same vent style higher in the picture.
          • Adenitz
            • Jan 2021
            • 122
            • Congo
            I will, thank you.
            • Adenitz
              • Jan 2021
              • 122
              • Congo
              I have exchanged faulty caps + one more as suggested. PSU now works OK. Output wires are not coloured, but I noticed there are now two stable voltages when PSU is off. One is 5.04V and this is most probably 5VSB. Other is 4.7V. This is most probably PSON that will be pulled low when power switched is pressed.
              Thank you for your help. Greatly appreciated.
                Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                09-06-2024, 05:30 AM
                HP Slim Desktop S01-pF0127d Slim Desktop i3-9100 Specification for Upgrade or Repair
                This specification for the HP Slim Desktop S01-pF0127d can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-pF0127d boardview and Slim Desktop S01-pF0127d schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                09-12-2024, 03:28 PM
                HP Slim Desktop S01-aF0005na Slim Desktop S01 J5005 Specification for Upgrade or Repair
                This specification for the HP Slim Desktop S01-aF0005na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-aF0005na boardview and Slim Desktop S01-aF0005na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                HP Slim Desktop S01-aF0017ns Slim Desktop S01 3250U Specification for Upgrade or Repair
                This specification for the HP Slim Desktop S01-aF0017ns can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-aF0017ns boardview and Slim Desktop S01-aF0017ns schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                HP Slim Desktop S01-pD0117d Slim Desktop i3-8100 Specification for Upgrade or Repair
                This specification for the HP Slim Desktop S01-pD0117d can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-pD0117d boardview and Slim Desktop S01-pD0117d schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
