HP G2 210 X2 - Schematic / Boardview
  • tdjb
    • May 2022
    • Austria
    I'm looking at a HP G2 210 X2 motherboard (dad91amb6e0 rev e) which isn't charging.
    No obvious visible defects, booting into Linux shows problems around smbus/i2c communications to the charge ic.
    Can't really tell whic ic is resposible, hopefully you guys have any clues, or infos about that board.
    Thanks a lot.
    tdjb
  • satishkumar
    • Sep 2015
    • 164
    • India
    Re: HP G2 210 X2 - Schematic / Boardview
    Originally posted by tdjb
    hi,
    i'm looking at a hp g2 210 x2 motherboard (dad91amb6e0 rev e) which isn't charging.
    No obvious visible defects, booting into linux shows problems around smbus/i2c communications to the charge ic.
    Thanks a lot.
    Tdjb
    • mon2
      • 14673
      Review the voltage of the I2C / smbus lines on the battery connector. Often there are local esd diodes that get damaged - that is their job if a transient is hit on the battery area. This damage leads to the I2C lines being stuck due to the damaged esd parts.
      • tdjb
        • May 2022
        • Austria
        Oh wow, thank you so much.
        Now I only need to find some time to actually look into it again.
        • PacoGT
          HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
          by PacoGT
          hello firends
          i search the schematic or boardview
          I have this motherboard, but I can't find the schematic or the boardview.
          The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
          So the computer doesn't turn on, and the 3V disappears after a few seconds.
          The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
          The new problem arose after removing the bad chip.
          3V and 5V remained together,...
          08-19-2025, 08:25 PM
        • hosain0489
          Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
          by hosain0489
          I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
          Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
          If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
          Thank you very much in advance!
          07-15-2025, 11:20 AM
        • re-atari
          Gigabyte GA-H110-D3A schematic/boardview needed
          by re-atari
          Hello all,
          Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
          This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
          02-24-2025, 06:45 PM
        • jonyhdtv
          HP ProBook X360 11 G3 ee (winbook) schematic and boardview thanks
          by jonyhdtv
          Looking for schematic and boardview
          Model: HP ProBook X360 11 G3 EE
          Serial: SCG9114JG7
          Motherboard: L43774-601
          defect: touchscreen doesn't work (touch works on another computer)
          thanks to all​
          01-29-2025, 08:16 AM
        • jonyhdtv
          HP ProBook X360 11 G5 ee schematic and boardview thanks
          by jonyhdtv
          HP ProBook X360 11 G5 ee (winbook) schematic and boardview thanks
          Model: HP ProBook X360 11 G5 EE
          Serial: SCG0164QLH
          Motherboard: L83950-601
          defect: no POWER
          thanks to all​
          01-29-2025, 08:11 AM
