Lenovo T430 with power issue need help
  • manuel.it.solution
    • May 2020
    • 30
    • Ghana
    Please a customer brought this Lenovo T430 laptop with power issue.
    When you press the power switch the yellow led indicates the power is on and fan spins for 10 seconds and goes off with no display or stable power.
    Please can anybody help me with schematics or what to do first?
    Thanks in advance
  • mon2
    • Dec 2019
    • 14187
    Re: Lenovo T430 with power issue need help
    I think that you have multiple posts on the same topic.
    For starters, do as per suggestion by @SMDFlea.
    The schematic should be probably the one posted here:
    https://www.badcaps.net/forum/showth...highlight=t430
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • claws77
      lenovo flex 5 14itl05 power sequence issue
      by claws77
      hi guys, my motherboard will not start no matter what
      when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
      but rest nothing happens no sign of life.
      this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
      with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
      but now nothing happens no matter how much i wait/ charge/ press and hold power button.
      i have no knowledge of motherboards ....
      10-20-2024, 02:48 PM
      by manuel.it.solution
      Please can someone help me on what to check first?
      Thanks in advance...
      04-20-2022, 05:10 AM
    • justice171
      Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
      by justice171
      I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
      Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
      1. Verified that all critical voltages are present:
        • 3.3V and 5V are always present if DC is plugged.
        • 1.8V on the BIOS chip is present.
      2. Checked the power button functionality:
        • When pressed, the voltage drops to 0V, indicating the button is functional.
      3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
        • Confirmed connectivity is intact, ruling out issues
      11-26-2024, 12:39 AM
    • hendeky
      Lenovo 15IMH05 Power Issue
      by hendeky
      I have a problem with my laptop. I just short circuit the eDP cable by an accident. Then i try to open it. i press the power button it was powered the rgb keyboard but after a few seconds and it just shut down. When i opened it up and unplug everything from motherboard i can't see any physical damage from ICs, capacitors and MOSFETs. I found a broken fuse FG3. But it just powers up LCD Display. I try to power it on with DC Adapter and feel some heat from an IC. IC is repeatedly power on and off. I tracked the schematic and i found some MOSFET and main 5V/3.3V controller. After that i...
      03-23-2025, 11:45 AM
