NEED BOARDVIEW OR SCHEMATIC nb8513_mb_v3
  • dqtech
    Badcaps
    • Jul 2018
    • 639
    • N/A
    does anyone have boardview or schematic for nb8513_mb_v3 (Acer Aspire 5 A514)
  • qonma
    Kuli Solder
    • Jun 2017
    • 185
    • INDONESIA
    Re: NEED BOARDVIEW OR SCHEMATIC nb8513_mb_v3
    same need foto area KBC
    • mon2
      • 14667
      Controller = IT8987 ?
        Acer Aspire 5 A514-52K Schematic and Boardview
        Acer Aspire 5 A514-52K / A514-52K-32NL Schematic and Boardview...
        10-01-2024, 03:56 AM
      • AlexWhat
        Acer Aspire 5 A514 LA-M213P REV1.0 BoardView
        by AlexWhat
        Acer Aspire 5 A514 LA-M213P REV1.0 BoardView...
        10-05-2025, 05:02 PM
      • PacoGT
        HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
        by PacoGT
        hello firends
        i search the schematic or boardview
        I have this motherboard, but I can't find the schematic or the boardview.
        The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
        So the computer doesn't turn on, and the 3V disappears after a few seconds.
        The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
        The new problem arose after removing the bad chip.
        3V and 5V remained together,...
        08-19-2025, 08:25 PM
      • hosain0489
        Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
        by hosain0489
        I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
        Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
        If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
        Thank you very much in advance!
        07-15-2025, 11:20 AM
      • re-atari
        Gigabyte GA-H110-D3A schematic/boardview needed
        by re-atari
        Hello all,
        Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
        This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
        02-24-2025, 06:45 PM
