HP Spectre x360 13-4005dx notebook Schematic kindly help
schematic HP HP Spectre x360 13-4005dx notebook
by tranquilityhello, i am very new to laptop repair and generell electronics
i have a HP Spectre X360 Convertible 13 - ap0016ng
motherboard number DA0X36MBAE0 REV E
massive burned and shortet mosfets. after removing them still shortet in the i think "main power rail"
found a shorted capacitor. removed it and the short is gone.
i want to try a crazy repairwhich is hard because the mosfets are like welded on one side to the track. is there a method to get this loose ?
in this area another capacitor was shortet.
HP Spectre X360 Laptop Schematic
DAY0DEMBAB0...-
Channel: Schematics and Boardviews
10-17-2024, 08:40 AM -
by snaeker58I have an HP Spectre x360 Convertible 13 - ap0121ng that is not powering on neither through battery not through USB-C, it also has no shorts. A schematic would be really helpful at this point. Many thanks in advance!
The motherboard model number is: DA0X36MBAE0 REV E-
by timematcherDear friends,
I am in need of the schematic diagram for DAX32DMAD0 HP Spectre X360 15-BL112DX (8th generation)
Thanks...-
04-18-2024, 06:08 AM -
by AJ847.63eHey All,
Just wanted to see if anyone has the above correct schematic and BV for this model. It seems like there are different variations with the exact same board label and revision as I've found BVRs labeled " DA0Y0DMBAF0 Rev F" which is the board label on the board I have here, but it does not match the board. The board I have has a large MLCC on it (where PR96 is) and when I continuity check it to the lines matching the BVR it does not go to where the BVR says it does, and the BVR lists it as PR96 when it is clearly a MLCC. I thought the revisions maybe mixed up in the...-
- Loading...
